18" problems haha I read that 295/70/18 rub with RC 2.5" on stock rims. I love the Z71 rims do i went with the safe bet 275/70/18 Cooper Discoverer. Love em
ImageUploadedByTapatalk1422328467.620829.jpg[/quote
Any more pics? I was thinking of going with the same size with the coopers or the KO 2
Just installed the MotoFab 1.5" leveling kit on mine. First side took me 2 hours, 2nd side took 30 minutes. Glad I did it. Closer to level, but I don't mind a little rake. Rear is 39.25". Front measurements below, and side view w/ the 1.5" kit installed.
Hi guys, I'm new to the site. I have a 2014 Silverado Z71. I had the chrome 20's but traded with my boss for his Tahoe gunmetal 18's. My father in-law lifted his Silverado and is giving me his tires 295/65/r18. He had a 3.5" lift and upgraded to a 7.5" lift. All i want is to level my truck but i am not sure if these tires will have any issues with a leveling kit. Is anyone running these size tires on a stock 18's with a 2" or 2.5" level kit. If so what leveling kit are you using? what brand? Thanks,
With either leveling kit you may have to trim the felt liner a bit as those tires are pretty wide.
I ran 285/65/18's on stock 18" wheels with a 2" level with no issues though. So you may be fine without needing to trim the liner.
I would suggest going with the taller of the 2... go with the 2.5". That's just my 2 cents though.
Thanks,
Would .25" wheel spacer help this issue? also does the leveling kit affect the CV angels? what brand of leveling kit do people recommend? readylift, bds, rough country?
Edited by pepsipopper2001
Thanks,
It might help, but i can't say for sure, as i've never tried it. And with the leveling kit, it doesn't take the angles to the extreme that would cause any significant wear to them. They may wear out faster than in stock formation, but I had my dealer install mine, so it's warrantied.
Any of those brands you named will be great. I use rough country because it's affordable and works well. The others are great too though.
Rough country 2.5 level on 33x12.5x22 Toyo M/T's
How is everybody's trucks riding with the 2.5" rough country kit? I had the 2" level on my truck(14 silverado) and it never drove straight after. Always had a pull to the left and this is after 2 alignments from the dealership! I am in a 16 Sierra now.
Edited by skennel23
I've had my 2" level on my 2015 crew cab for 3,000 miles now with no pulling or change in ride. Thing is perfect!! I kinda regret not getting the 2.5" now lol
So, I have a 2.25" spacer that I have yet to put in. My question is to the guys that have 2-2.5"... Are you guys running rear blocks with that spacer? and if not, is the front sitting higher than the rear or is it sitting level? my fear Is that I'm going to be too high on the front... Thoughts?
I have the RC 2" level block under the strut. I still have a tad bit of rake and am thinking about adding the 1/2" spacer on top. I'm still running the factory block in the rear.
Edited by 8ty8 ls1
I'm running the MotoFab 1.5" leveling kit. That's it, nothing else. Front is 1" lower than the rear, which is exactly what I wanted. Just a slight bit of rake. Made a big difference in the look of the truck, that and removing the air dam.
Sent from my XT1254 using Tapatalk
I have the 2.5" in front and stock in rear. I sit 1" high in front. If you don't tow a trailer, this may work for you. I'm running 305 55 20. Rides good. I'm going to add the rear block to bring it level for when I tow, I won't be so nose high.
Has anyone had problems with the RC 2" front level (lower) block? I went to a 4x4 shop and the salesman was telling "sorry about your luck". "Who installed it?" I told him I did and then he had the balls to recommend that he take look at it to make sure it's correct.
This is pretty good info, thanks, so... of the two of you, one with 2" with still a little rake, and one with 2.5" and a little nose high, I'm pretty sure I should be good right in the middle with my 2.25" installed. Going to run 275/60R20 Toyo Open Country AT2's come next spring. Thanks for the feedback!
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
    • It get absolutely nothing. No chimes, no dash lights, it won’t crank. It’s completely dead outside of the obd2 port which is throwing no codes. I’m wondering outside of a rusty ground somewhere if it could be a connection on one of the fuse blocks? I would not be surprised if water could get under the main panel under the hood on the drivers side.
