Sharp looking rig! What are you running up front? And may just be the angle, but anything in the rear?
Sorry meant to quote you.
2" level in the front +1" block in the rear. 275/65-20 (34") tires.
Rough Country 2.5" and 35x11.50 Nitto Ridge Grapplers
Yup! Made my new setup pretty easy to decide on.
My thoughts as well.
Considering these are bigger than a 285/65/20, and everyone says those rub, I just don't see how it's feasible without some rub.
Well the air dam is removed so that helps, but it looks like he has positive offset, so that hurts. I would say that it does rub somewhere. Probably on the rear inside of the front wheel liner.
Just got my leveling kit in last night!! Cant wait till I install them over the weekend!!
I decided to go with the 2.5" kit
OK, I'll bite. Where do they rub?
it rubs the sway bar at full lock. I cut the inner fender liner so there is no rub there
Edited by THE_Engineer
anybody got picture with a 2in front and rear with stock tire size... im buying the rc 2.5 kit but i think it would look weird with stock tire at 2.5 so im thinking going with the 2in f/r like my old truck was
This is a 2" front w/ factory tires. I don't think another .5" would look that bad. when time for tires just go up to a 33
you got the 2in at the back too??... i wont put tire on for a while since i got ko2 with the truck
No, just the fronts. Thought it would give you some idea of what it would look l like. My wranglers have 23K and about 10K left. cant wait to upgrade tires.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
