On 12/30/2016 at 5:49 PM, CHowell1991 said:
I got my 2015 leveled yesterday with 285/75r18s on stock wheels. 2.25" readylift. e9fb32455eb6e7a1ab4290d687ba3600.jpg4f06d63c867457887ff070665de117df.jpg
U have any rub or trim on that set up
Do they rub and any trim u had to do
On 11/15/2018 at 2:28 PM, TXGREEK said:
Everybody get ready!
Awesome Black Friday deals coming
Sent from above
I’m trying to take advantage of this, but can’t get ahold of CST via email, phone, or facebook messenger.  I’d like to get their front leveling coilovers and upper control arms, but don’t see any matching rear shocks on their site.  Does anyone know if they offer a basic Dirt Series 2.0 shock non-resi to replace my stock Ranchos?  Something exactly like the FOX 2.0 and Icon 2.0 non-resi shocks.
The closest part number I could find on their site is the CSR-5530 but that is listed for the new 2019s only.
On a side note, MRT and SDHQ have been very responsive to questions about other setups that I am pricing out.  Right now I am leaning towards the Icon stage 1 and will add their delta joint UCAs.
Edited by BbyDgital
They may be closed for the holidays, try them back on Monday. They do have the shocks you want.
The dealer had put on 22s.  I had them changed to 18s.  I also had Bilstein 5100s installed at the highest setting and also replaced the shocks in the back with Bilstein.  I love the stiffer ride.  I don't bounce all over the place now when I hit a bump.
Can anyone post a picture of what their ball joints look like with the 2in Rough Country leveling kit? I need to compare them to mine.
I'm sure this has been asked, but I'm lost and a little confused yet.
For my 2018 Sierra 1500, I am going to add GY DuraTracs, 275/60/20 (a 33" tire) and a 1.5"-2.0" front level kit (Rough Country).  Do I need to do anything with the UCA?
Not RC bit this is what mine looked like when I had the Readylift 2.25"
Sent from my SAMSUNG-SM-G890A using Tapatalk
Thanks, did you Readylift kit come with UCA's? I don't see the ball joint as crushed as with a Rough country 2in Kit.
Edited by Morenar
mispelling
It did not. This picture is with the stock stamped steel upper control arms.
On 9/12/2018 at 5:37 PM, SNAFU88 said:
Didn't care for the nose-high appearance of the truck with the 2" level so I installed the 2 inch rear block to give it a bit of rake again.  Subtle difference but just enough to fix the problem. Before and after:
80-_img_2218_e5853e5f6a94e36608f0f7f4897
80-_rearblock_624115fe5289acb3707d038cd4
I love your wheel and tire choice.  That looks great.  Very old school and cool. Any other pictures?
Thanks, man.  285/70-17s on 17x9 et -6 Pro Comps:
80-img_5404_4fab0d5fc7b42be38382f1088b05
80-img_5409_b6b3c15a4768edb60c3fd7e21127
Recently added a tool box:
80-img_0522_b7d7932291350f5e51f9f0d9783a
I asked this question above, but I am also contemplating going 285/55/20 instead of the 60 tire to avoid any potential rubbing.  That tire is about a 32" tall tire, so only 1" taller than stock.
Would that 285/55 be a better option to avoid rubbing and potential UCA issues?  I really do not want to get into something and then have to throw a bunch more money trying to fix it because it was the wrong tire choice.
Edited by SouthpawHD
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
