285/65r18 ko2's on factory 18s. 2.25" level. This was before i debadged and blacked everything out. No rubbing anywhere.2eb5d78d76704cdbaf1870f9d2162fcf.jpg
Sent from my SM-G950W using Tapatalk
On 11/21/2018 at 10:30 AM, askibum02 said:
Got mine taken care of this weekend.  275/60/20 Ridge Grapplers and a 2" RC leveling kit.
45262301724_abe91e61c9_k.jpgIMG_6087 by Brett Valentine, on Flickr
45986578361_9dfb36fa7e_k.jpgIMG_4688 by Brett Valentine, on Flickr
44170419960_3543d0342f_k.jpgUntitled by Brett Valentine, on Flickr
I think I'm going to pick up some vinyl and black out the emblems, get an exhaust put on, and get a tonneau cover, and that's pretty much it.  I'm really happy with the truck overall and can't see getting rid of it any time soon.
This makes me wonder if my 275/65/20 tires will work with a level.  They are the same width...just a little taller.
  The 275/65-20 is a full inch more diameter than the 275/60-20.  That is not "just a little taller."  When dealing with these trucks and levelling kits, that's ALOT taller.
:) Ok I can agree with that.  But the rubbing is only with wider tires right?  Not taller.
As of right now I have 0 rubbing on my 2018 Sierra Max Tow
Just had the Nitto Ridge Grappler 275/60/20XL done on my 17 Sierra. Love the ride, just need to figure out the correct tire pressure. Any recommendations?
I’ve got the same tire 285/60/20’s, running them 38-40 psi
Thanks, I did the chalk test yesterday and 37psi seems to be the sweet spot on mine.
That looks VERY nice, love white with black wheels...
You’ll love the tires, very durable
I did a 3inch front 2 inch rear and i also did a diff drop as well to alleviate some of the increase angle on the cv joint , i didnt notice any ride quality change but def do a front end alignment!!!
Have you picked out wheels and tire?
Give you some advice, didn’t notice whether it’s a 15 and up but mid 15 the dreaded new stamped UCA’s came to be and I myself had serious issues leveling, adding 275/60/20’s with horrible rubbing. Pick out your tires first and see if they rub and go from there before you invest in wheels too. This way, you’ll know the offset required to clear in the event it rubs.
Good advice but I have 22's with the ultimate Denali package and want to go to 17" wheels...  I figure I will follow your lead and get 285/70-17 KO2s on 17x9 Pro Comps.  If they rub, you can pay me for new tires.
BTW I can't find "17x9 et -6 Pro Comps" on their website - this is the closest I found = SERIES 5045, 17X9 WITH 6 ON 5.5 BOLT PATTERN - SATIN BLACK. Is that the right wheel?
https://procompusa.com/wheels-product-details.aspx?pt=101508&lc=PXA&pqq=2336-1558-1551-1557&pqa=16948-8275-8059-8268
I believe you have me mistaken with someone else
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
    • I had a Gen5DIY DRL relocate harness from a 2022 1500 that I saved. I had Gen5DIY modify the harness for my 2024 Silverado 2500. Plug n Play, worked perfectly.    Here's a video I made for the 2022 1500 truck. The install is more or less the same on a 2500.    The harness relocates the DRL tot he top amber turn signal on my 2500.
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
