2 inch RC Level front nothing changed in the rear and 285/60R20 Ridge Grappler
before and after
Guys
I’ve read every single post in this thread, but I’m simply confused on what I need to do for my truck. I have a bone stock 2018 Sierra 1500 Denali Ultimate 4wd (22” wheels). I’m simply trying to raise the front of my truck up to level with the rear. I plan to keep the same stock wheels and tires. Can someone tell me what I need to get?
Thanks for the help. I’m not knowledgeable about vehicles and I need some help deciphering all the info I’ve been reading.
You end up pulling the trigger on a level yet? I'm in the same boat now.
I have a 2018 GMC Sierra 4WD that I had a locally manufactured 2.5 inch kit installed by a reputable shop which included 2” blocks in the rear. I love the new stance of the truck but now it has a vibration felt in the floorboard of the truck. Nothing through the steering. Any suggestions?
What did the shop say about it?  That's the first place I would go.
Are the rear blocks tapered? If they are straight that could be a possible source of the vibration since you are changing the pinion angle. I am on the fence with doing an add a leaf or a +1" tapered block from readylift myself.
Sent from my SM-G950U using Tapatalk
Sorry didn't mean to quote yours.***
before and after
Nice truck (twin).  You say you did the 2" up front only but in your signature you mention the 2.5.  Did you do the full RC 2.5 kit or did you do just the less expensive option and lift the front only?
I did go back to the shop and discuss it with the owner. He just blamed it on the change in pinion angle and stated that the new angle should seat itself after about 500 miles. He also stated that he had installed this kit in many other trucks with no issue.
I am not sure if the rear blocks are tapered or not. They were used rear blocks from another truck that he had performed a lift on. I think that I am going to remove them and reinstall the stock blocks just to see if the vibration goes away.
You can get tapered blocks from just about anyone. Look to see if if the rear blocks have a slight angle, looking from rear to front your rear blocks should have a slight angle downwards towards the front of your truck. Not having the right blocks will definitely give you vibrations and it’s an easy cheap fix.
Sent from above
Thank you. I will definitely check that out. Any idea how much of taper the blocks should be? I read on another post something about 2 degrees.
Pinion angles don't "seat themselves". That's just them trying to say they did nothing wrong. The block kit i plan to buy that I would recommend is in the pic. I used ready lift blocks and u bolts on my old Silverado with zero issue.
I would strongly recommend replacing the u bolts if you go with another kit as they have a tendency to stretch when they are torqued. One benefit to the ready lift u bolts is they utilize fine thread pitch, where the oem is coarse. The fine thread pitch has more mechanical advantage when torqued and will not come loose. The oem u bolts are prone to loosening (happened to me when i bought my truck, and numerous others on posts i have read). Good luck. 22de9080d6d8173928309dd27a89d8f1.jpg
It’s going to be more of a universal slope but most of all you should know it’s all going to be worked out. As soon as you can, take a side pic of your rear blocks. Where are you located?
Sent from above
I am located in Northern Florida.
Look for 4wheelparts, they’ll be available to help you. Call them and ask to speak with the manager, tell him you were told to contact them and get assistance with an issue. Don’t tell them where you had it done, just tell the manager your issues. IM me if you need assistance.
Sent from above
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
    • Hello Guys I'm new to the form,         I just put a 7-inch Rough Country lift on my 2016 GMC Sierra 1500 with the 5.3 and I also put a Borla exhaust on it. But I noticed when I'm in park or in neutral and then I rev my truck up really quick there is a bad click noise and I think it's coming from the motor somewhere. Anyways I got a video of it I will attach below I was just wondering if you guys think its rod knock or lifter tick or something like that because I know the AFM kind of made the lifters weak on these trucks.       Thanks!!!!! RIP - Chevy 5.3 IMG_6043.mov
