On 5/17/2020 at 1:36 PM, Pig Sooie 4 said:
2018 Chevrolet Silverado LTZ with 295/55/20 Nitto Ridge Grapplers and a 2 inch rough country leveling kit. I know a lot of people like aftermarket wheels but i love the stock LTZ 20s. Thinking about possibly doing the 2.5 kit on the front and the 1 inch block in the rear.
How have you liked the 2" rough country kit long term? Any issues/complaints? I have same truck color and all and was thinking about the RC 2" leveling kit and Nitto Terra Grapplers but I haven't pulled the trigger yet. Thanks!
I haven't had any problems. I ran a 2 inch level kit on my last truck and never had problems. At times i wish i would have went went the 2.5 inch kit but i am fine with this one. A lot of people think 2 inches should be the max though. What size tires do you plan on running? I thought about 285/60/20 for my next ones. I am fine with a little bit of rub. Put some pictures on here when yours is complete!
I looked heavily into the 2.5" as well but dont want the extra stress on the suspension components etc. I also like the little bit of rake the 2" has. Ive been looking at 275/65/20 with the stock rims as I really like the looks of them as well. Im also purchasing bilstein 5100 shocks and struts to replace the stock ones. I will definitely post pics after I get everything installed, I appreciate the feedback!
Off topic but does your silverado have the 5.3L with the 6 speed? If so I have a few questions regarding some mechanical issues ive been having with mine and would like to see if other owners are having similar issues. I can send a direct message too so I don't mess up this thread with off topic questions if that's cool with you.
Thanks!
I have a 2016 Chevy Silverado LT currently running factory 265/65/r18. I just ordered a 2" leveling kit for the front. I really want to keep my factory 18" wheels and want to know what tire size I can run after I install the 2" level on the front. Thank you.
I have a readylift 2.25 with the UCA in my 2016. I only have 21k miles on it and the ball joints already have tons of play. I have not been able to find a MOOG direct replacement. Readylift if sending me new ones for free but i mean.... id hate to put them in and change them again at 65k miles. MOOG K6540 fits but the taper is too small. I would need sleeves... sigh. Have any of you had luck with other brand control arms? I don't mind spending the extra money if it means not changing ball joints every 20k.
Thanks
Sent from my SM-G950U using Tapatalk
Lots of different opinions on here. Some rub, some do not. Here’s my story. My previous truck, before it got written off was a 15 Sierra all terrain dblcab. It had a 2.25 ready lift in the front and a 3” block in the rear, sitting on 275/65-20 ko2. No issues with rubbing but rode rough with the e rated tires. Present truck is a 19 limited dblcab. It came stock with a pretty good factory rake. I installed the ready lift 2.25 kit 66-3086 which included the new a arms and ran the same e rated and size ko2. Not only did it ride rough but now rubs the a arm at full lock. Sold the tires and installed p rated duratracs in a smaller 275/60-20 size. The ride improved significantly but it still rubs the a arm. How? Other guys are running a little wider tire with no issues or so they say. Note I’m running the factory wheels on both trucks. Contacted ready lift and they said to run spacers, 1/2”. Don’t really want to install spacers. I may remove the lift all together. Does this make sense to you guys?
Iceonly ,
Did ready lift verify that you bought the correct kit for your truck?
Gm has used 3 different upper control arms on these trucks.
The reason i would think it is the wrong kit would be the tire size change is neglible.
Obviously this a design issue as you replaced the a arm.
The good news here is that you should be able to leave those spacers in there and just change back to the factory arm and have no more issue.
All the new a arm does is change the ball joint angle.  So that the ball joint doesnt wear out quickly.
My previous generation gmc ran a 2 inch level with significantly larger duratracs o er 60k with no issue on factory a arms.
My currenty truck had a two inch level for 1 year and no runs a 5 inch lift for the past 5 years . No ball joint issue. Factory control  arms.
Thanks
Readylift changes the angle of the a arm. Which bis supposed to change angle and give you better life. Better it does not affect ride . Height. The moog will would be at a factory angle.
Cognito is supposed to make top notch products. Uniball joints are the way to go but they are pricey.
Rough country also make arms for lifted trucks as due most of the lift companies.
I would give you the same advice i gave the last guy.
Put the factory control arms back on and give them a try.
The good thing is control arms are easy to change.
Although you shoukd have it realigned if changing control arm styles
1 hour ago, mrhonestlyinsane said:
Iceonly ,
Hey. I’m pretty sure it’s the right kit. The only reason that I changed the a arms is because my truck now has stamped steel ones. My 15 had aluminum ones. I removed the bottom spacer this morning to bring the front end down 3/4” and next week I will put the factory a arms back on. They are smaller in diameter than the ready lift ones so I’m pretty sure that will solve my rubbing issues. Really don’t want to add 1/2” spacers.
So I read from page 450 to this last one. I have a 2018 1500 with factory 18” wheels with obviously stamped UCA’s. I’m looking for a little beefier look but don’t want a lift. I’m torn between the bilstein 5100s all around at the top setting and a bigger lock in the rear (for 1” of lift in the rear). The Eibach pro leveling kit. (Possibly with springs but heard it tides rougher with the pro springs vs stock) and a bigger block in rear (again to get 1” higher). Or possibly the ready lift 2.25” leveling kit and again a bigger rear block. I don’t want the truck to ride like crap my questions are with bilstein and the eibach kit will I still need aftermarket UCAs with bigger tires? And what would be a better tire to run without rubbing 285/65-18 or 275/70-18. Or am I missing a tire size. I don’t want to worry about it rubbing I understand there are a lot of issues with rubbing with factory wheels but I really like my stock wheels and don’t want to have to replace them. So what would you guys recommend between the 3 and tire size? UCA replacement. I saw a lot of talk about 20” factory wheels but not 18”
I’ve had a 2” RC level on my 2016 silverado basically since I bought it (4 1/2 years and ~80k miles later)...I am looking to add the Eibach pro truck level/lift kit...(springs and struts, front and back)... it advertises as a 2.5” lift in the front... I know that is the break point if you will for after market UCAs being recommended/required... I’ve seen that RC has a new(ish) forged set... that seem well better than some of their older stuff... what recommendations do you have for good value (not super expensive) UCA that work without spacers and factory wheels for a 2.5” ‘lift’?
Edited by spenpet
Spelling
Hey guys,
I just ordered my Eibach Pro truck Lift kit and plan on running it on the bottom setting to give me 2.5” lift up front and I’m going to replace the stock blocks with a 2in Motofab block. Also throwing on the RC Forged upper control arms and new Moog outer tie rod ends.
I’m not sure what wheel and tire to go with and looking for some help... I love the bronze wheel look but not sure how it will look on my Iridium Metallic with chrome front end. Otherwise I was going to play it safe with some black milled Icon Alloys. Looking at either the 285/70r17 Kenda Klevars or 285/75r17 Cooper Discoverer AT3 XLT. Not sure on Tire size either.
Drop some photos of the Bronze wheel look! Much appreciated.
Edited by JsierraZ71
Spelling
Hey guys,
It’s potato quality but here’s an example -
https://www.methodracewheels.com/pages/chevy-wheels
I’d go with bronze and the 285/75/17 coopers, I love mine. Check out my build thread for pics
I found a picture from SDHQ’s website. Saw you have their skid plates. Pretty badass! Love the Bronze wheel look too. I’ll post pictures of mine once I finish installing everything.
How many miles do you have on your Coopers? And how have they been off-road for you?
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
