  • txab unpinned this topic
Very clean. Is the LT4 supercharger a pretty straight forward install on these? Is yours a 5.3 or 6.2?
? I would edit your post. You do not want to ask him that question. But yeah, its a 5.3.
Edited by M1ck3y
  • Haha 1
  • Sad 1
[emoji1787] I would edit your post. You do not want to ask him that question. But yeah, its a 5.3.
Well I’m not going to go research his experience. He’ll answer or he won’t.
Last pic before I traded it in on a T1. I think over all I still like the K2 trucks a bit better. Needed a crew cab for my growing family or I’d still have my 2016 Double Cab.
11 hours ago, Derekken said:
WHAT DROP DO YOU HAVE?  LOOKS LIKE A 3/5
It’s part number K34170 at suspensionsuperstore.com
2” Spindles and adjustable struts set at 2” - so should be 4” in the front.
Flip kit/hanger/shocks in the rear, hanger set at the 5” hole.
Should be 4/5 but I haven’t measured since everything settled in. Had the strut set at 1” to start and it didn’t look right so pulled it back out and set it to 2”.
i was thinking of doing ihc 4/6 drop, but i really dont want to run helper bags so might end up doing a 3/5
I’m still going to have to install helper bags for when I haul or tow stuff. It rubs in the back wheel wells over big bumps if I don’t see it in time to slow down. Haven’t installed the bump stops yet. Front rubs worse on bumps and at full lock going forward and about half lock in reverse. Running 285/45/22 on replica wheels.
On 11/15/2020 at 5:46 AM, TrkNrrs said:
Personally, I dont like it. I'd buy a car before slamming a truck. But to each their own, keep up the good work!
That thing is slicker than Fish **** Mainnnn !
Yotaman
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
