Very nice. My buddy used to drive up there to have his 2500HD dynoed and tuned by him. Long drive to Ohio from P.A. but his experience was worth it.
Sent from my Nexus 5 using Tapatalk
Nice. Yeah Smokeys is a very good recommended shop across the board. There was about 4 mil worth of cars/trucks in the building while I was there haha. New C7 laying down 780hp to the wheels.. I got to sit in it.
Nice, I just got my truck in and have been looking for what to put on it.
Looking at your sig, is your CC have the standard bed or short bed? This system is for the short bed CC's or 143.5" total length models.
GM dealers will be able to get their hands on Borla systems made for GM Accessories. Apparently they also have something the other guys don't...the OEM GM AFM flapper valve in the system for drone elimination..
CC standard bed, any recommendations then?
Keep cking Magnaflows website. They are steadily adding systems for both length trucks.
The single side dual outlet is nice but there there is no resonator(s) so it may be loud. I like the resonator to keep the tone mellow. Some guys want it loud so they would prefer a system without a resonator.
So many options...price ranges, etc. I thought I wanted Borla..but seeing so many others. Corsa looks relaly nice. Decisions, decisions... How did everyone else pick?
Do a muffler delete go from there, only you can decide this one. This is the cheapest way to start.
I'm not a Borla fan at all..... Djones who is one of our members, has a sound clip of his truck with a Corsa cat back and it sounds really good. I have been debating getting the Corsa but I need to hear it in person, I wished he lived a little closer so I could go for a ride and see what the interior noise was like on the highway and under moderate acceleration. I hate to drop that kind of coin and not like it, I'm real picky when it comes to exhaust.
That's where I'm at too. I dont want to spend that kind of money and not really like it. Curious why you dont like Borla? Seems to be good stuff and have a nice sound. I've been scrounging youtube for videos and such...some are kind of lackluster. I was looking on summitracing.com and they have a bunch of systems, they must have 12 or so different Corsa systems just for the 2014 Silverado extended cab, short bed. I have no idea why there's so many systems or part numbers listed. Incase you havent heard it, here's a vid of Borla's system for the 2014 Silverado / GMC.
I kinda like the sound of that "S" type.
Go with a Corsa Sport. It's worth the extra coin I've said this many times. Also has ZERO* drone
Ok... Ok... it sounds good at idle, now go get us a good in cab video/sound clip along with mounting that camera to the back bumper by the exhaust and doing some burnouts, launches, 70mph steady driving, part throttle in town acceleration... screw it... just come pick me up.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,189 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
