No pics yet because the weather hasn't been great, but I installed my 2" Rough Country, and got an alignment . Also added this stubby antenna today. [/url]">http://
[/url]">AD4EBDDB-F991-40FF-9C0C-89B078C464FB_1.j
85a969c8dcfcfa2d856442bfe95eea8c.jpg Foamed her followed by a good claying, CG Blacklight and Optiseal....probably put down a couple coats of PB Nattys Blue in a day or two. Wanted to get it protected and ready for winter. e3315fe95bebb6c639bae0a62f17a288.jpg31305cf891d7f8f34371737a7f192376.jpg8b2b76af18b1e490e6b252e2e231ca6f.jpg
Sent from my Note 4
what make/size tires are those truck looks great!!!
How well does that antenna work ? who makes it ? looks good.
It seems to work just as well as stock so far, maybe a little loss on one station that I use occasionally. It was always questionable anyways. I picked it up at the local auto parts store, it is made by Metra, and was $18. Cheap, easy and looks good.
Well i deleted my air dam the other day (see post 5236), and while i think it look better removed, it just looked as tho something was missing... so i decided to trim it down and reinstall as a few others have done. Looks much better now imo. Finishes the lower bumper area out nicely.
Just took my 16 to the dealer to get the 1000 mile break in oil changed.
Ummmm ive got 3,000 miles on mine with no "break-in oil change" done. I see no mention in my manual either... should i be concerned here?
No, not at all. Just personal preference. I did oil and all driveline components at 1k miles, I'm a stickler when it comes to maintenance
Not at all....its just something I like to do....
Did your dealers give you the free oil change at 1000 miles? Mine told me the oil life percentage had to below a certain percentage, I forget maybe 20%, before it'd qualify for the free oil change. Something else I noticed later was the details on the free oil changes. Up to 4 free, 2 per year max, 24,000 miles and 24 months. Dealer recommendation and oil life meter seems to get you around 7,000 miles between changes so I'll never get that 4th free one at this point unless you guys have had luck getting your dealers to change it at any interval?
Edited by mjj
Modified the factory alarm to trigger on locked entry handle pull.
Details here http://www.gm-trucks.com/forums/topic/177069-help-with-alarm-trigger-mod/page-3?do=findComment&comment=1693523
Nice touch, but I could see that getting old very quick. Many times I go outside to my truck to grab something I forgot to find my door is locked. My neighbors would hate me.
You won't see it in the maintenance schedule as technically, GM doesn't use "break-in" fluids as they once did. However, you will find a lot of owners do their first oil change (and other fluids) early just as personal preference. Personally, I don't put a lot of miles per year on my vehicles, so my first oil change was at 3,000 miles (I had my first 4 done at 6 month intervals, then switched to full synthetic, Mobile 1 and it will be one change annually). Now, I should also tell you that my dealer provides the first 4 oil changes during the first two years at whatever interval the customer desires and does not limit it by the OLM percentage.
You will hear as many opinions on this as there are drivers...
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
    • It was all part of the tiny bit of fuel savings it goes towards what was mandated by the government. Much like cylinder deactivation. That was relaxed by the recent administration. All that doesn’t help the individual buyer. But as a whole helps the manufacturer to try to reach the previous ridiculous past mileage per gallon mandate. So yes it was mandated and added cost to the vehicle.
