Washed and detailed the truck and installed the DL3 mirrors and PGamboas’ mirror harnesses!! Lovin’ it! Next up only 2 more mods to the interior (heated steering wheel and swap wood grain trim for off-road carbon fiber). Thanks again Phil!!
425d6a28d113edc69692c4be0c1e0f4e.jpga7b0d6d9878e7f21a40b3687cc6a06c9.jpge3e175a5cf398b1f6bf589749b68c6fb.jpg8a5428ef5c473a4aa3c8246fb973e86e.jpg
Edited by MHPrior80
18 hours ago, 300 Blackout said:
Found my illusive oil leak and am happy to say it’s a simple fix. There were never drops of oil under the truck, just a small amount of oil on the lower radiator support, electrical harnesses and trans cooler line. Originally I thought it was the trans line but after getting out the ol’ bore scope, I found one of my engine oil cooler lines wasn’t seated completely in the GM push-lock style fitting. Once I removed the black cover which protects the C locking ring, I was able to see part of the ring wasn’t sitting flush. Looking closer, I could see that one of the retaining tabs on the ring was only partially seated. I’m gonna replace the entire fitting rather than mess with this one. Grand total of $7.
a33308b19d23e68ed42d339b83a72309.jpga4b118d01bb2b8d1c6174dcb32ee7650.jpg486f28f2af80e2bb5b001d823482528f.jpg
These clips were a PITA to get re-seated when I installed a new AC Condenser. Key was to get the
cooler line piping all the way in so the clips could properly set all the way in.
Did you replace your condenser at some point?
The dealer replaced it a year ago. The truck had the frame replaced in January and this likely occurred then. If so, this is literally the only hiccup from that service. I’ve been very pleased with the work that shop did.
I will say Amen if that is the only issue after replacing the entire frame!
Why was your frame replaced? Accident or severe rust ?
Brought it in for its 15K mile maintenance, 14,131 on it, now.  It’s being washed, now.  Then I’m going to go get some food for tomorrow’s dinner party. Making Kalua Pig, rice, Mac salad, and serving it with Hawaiian King dinner rolls or buns.
Will you be taking a dump after that?  Or filling up with fuel?  Be sure to let us know.  :D
Bought the redline lettering
Going to place it somewhere new I hate it being right where dirt flys up from the wheel the chrome ones always look gross
I will do this for the next one.
I don’t know if it’s the same for everywhere but onstar gave me a statement saying that if my vehicle is ever stolen and they can’t find it they will gift me $xxxx amount of money I’ll see if I can find it in my files if you want me to take a photo
Added an AVS Aeroskin, couldn't find many pics of these on Sierra so figured I'd take some and post here.
Cool! If you find it, I’d certainly appreciate it, but don’t go to much trouble.
On another Note: I drove a 2019 GMC AT4 loaded with a 6.2. My goodness!
I did this all a few weeks ago but just now getting around to posting it.  Installed a pair of ARH headers that i got from a member here along with new NGK spark plugs and MSD wires while I was in there.  I then got a Magnaflow 12587 to 3" tips installed with a BBP tune. As of right now i think the MF 12587 is too quiet.  Im fairly certain with this setup the engine noise/header noise is louder than the back end of the truck.  Im leaning towards either a MF 14161 or a Jones 3535XL to a single 5" tip dumped after axle.  The BBP tune is easily the best mod I've done so far. I highly recommend it to anyone that has any sort of shifting issue with the 8 speed tranny.  It completely transformed how the truck drives and its much more enjoyable now.
So what’s involved in the BBP Tune? Other than the tune itself? Any physical upgrades? Or all computer? I’ve never done that type of mod before but I’m increasingly interested in something like this having had the truck for a bit now and seeing for myself what everyone doesn’t like about how the 8-sp shifts.
No physical upgrades are required. The tunes will work with a stock truck or all the way up to heavily modified.
You record a data log from a driving session with the tuner device (AutoCal), and pull the stock ecu and tranny maps. Email them those 3 files to them with whatever your goals are for the tune (remove speed limiter, firmer shifts, remove torque management,  etc.) And they will email you back your new tune. You then upload your new tune to the truck.  Its a very easy process.
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
