Got around to pulling all the parts out to make sure I have everything. The engine should be out tomorrow and hopefully new parts will start going in.
quick parts list
-L86 manifold with additional port injections. (will be installed with 50lbs injectors but won’t be hooked up just yet)
- 2000cc meth injection
- Borg S476 with billet wheel
- Cam Motion turbo cam
- BTR .660 dual valve spring
- Johnson 2110R lifters
- CHE trunnions
- Turbo Smart WG / BOV
- ARP head and main studs
- L86 OEM crank
- GPI “drop in” pistons and rods
- OEM head gaskets
- custom Garrett core intercooler
- Derale trans cooler (will be under the bed). Removing the 40k Trucool from up front.
And a bunch of other little stuff.
Edited by CajunFries
  • Like 4
1500 PAGES?!!!!!  HOLY CRAP!!!!
Drove my truck for the first time in 10 days, $8/gal sucks, been driving my son's car or my wife's CR-V Hybrid, and driving my truck once every week or two.  As I was driving down the main drag in town, I heard something flopping in the breeze under my (open) sunroof.  I usually drive for about 10 minutes or miles with the sunroof in vent and shade almost closed, to draw the heat out.
Found it to be a VERY simple fix.  Just re-engage the clip/slot from the front to the back.
Edited by Ravenkeeper
$8/gal?!?!? Where are you at?!???
I removed the plastic fender pieces and pulled the wheel well insert. Gave everything a good cleaning, then re-installed.
Super easy to do, don't need to remove the wheel. Just a T15 bit and a phillips screwdriver.
finally received the builtright bedside rack, I'm 2 days into a rather mean cold that has me wore out, I will try and piece it together in the next couple days
Ok, I exaggerated a little bit.  Average price around Antelope Valley (Lancaster/Palmdale) is $6.75
Ahhh gotcha. I havnt been out there in a while. Used to ride at willow spring all the time.
10ft of heat sleeve for the AC lines and couple of wires and Heat shield for the battery trying to protect it from the heat from the turbo. 35D83E49-FC03-403F-81B9-2F4ED8B52782.thumb.jpeg.9b3e265033247dd0d6266fe5eac62bb3.jpeg
I am definately going to do this for my 18.
Finally got a chance to test out my new electric pressure washer and foam cannon. Was too into the wash I forgot to take a picture of it all foamed up. Clayed/waxed after the hard winter neglect, full interior detail as well. Much needed!
Next week going to drop the trans pan and change filter/oil. 48k since the last time it's been changed and shifts are starting to firm up more than I'd like. Hoping to get as much life out of this 6 speed before I start getting the itch for a new AT4...
  • Like 5
What have I done for my K2 today. Well great question. I ended up finding a torn CV boot. Now researching my options.
  • Sad 1
Insulated the doors with ccf and ccf/al. Sounds better for sure. Now to chase down a door panel rattle.
Edited by Snowcamo
  • Like 5
finally got around to getting the builtright bedside rack system together.
comes with absolutely ZERO instructions, not a big deal but assembling some of the quickgrip stuff it would be nice to have a general idea of how it is supposed to be, there website has some install guides but none for chevy
I have a bedliner installed so it has complicated things a little bit, the bottom attachment is not ideal it is a U shaped bracket but should be a u-bolt or a j bolt or at least have a L leg so you can turn it and snug it up that way, the way it is it now it just binds up so I bought some longer bolts and sleeves at the hardware and will finish it up in the morning.  I may end getting a u-bolt and drilling a couple holes in the rack I could not find one that would fit the existing holes
  • Like 6
Had my passenger side rip late last year. Easiest and quickest option IMO... replace it. Took me about an hour, worst part is getting the dang thing out! Ended up having to remove the bottom 2 strut bolts, and sway bar end link which gives you some additional room with the lower control arm dropped.
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
