1 hour ago, Rad_Rado17 said:
There's a bunch of youtube videos covering these set ups.  Check out Dirtking, 454 motorsports.  454's youtube page covers all the trucks they've done with detailed videos.  As far as pictures, I would just search Silverado longtravel and there should be more than enough to check out.
Thanks man!
Welp, my radiator fans were on full blast again the other day on my way to work, turns out the coolant temperature sensor was not the culprit after all (replaced back in May).
Currently installing a new thermostat, which I am confident will solve the problem. My temperature gauge has barely been reaching 185, and after a couple of driving cycles during my commute in the morning it drops down to 160 and turns the fans on.
It's actually quite hilarious, I think it's trying to tell me something, haha.
haven't really been doing much with mine but I finally bought a Metra DSP. I have been using a couple JL amps with hi/lo adapters and using the audio signal as the on/off trigger and at low volume it's not enough to trigger the amps on, I am still using the stock head unit mostly because there is not really many choices out there for "kits" but the new stinger seems a little better looking but still holding off on changing the head unit the "floaters" just do not do it for me. The metra can be adjusted with a phone app, not many reviews on it out there but it seems to be there "universal solution" and has been out for a while already. I just have to tuck this in behind the radio and run some rca cables to the amps and should be golden.
  • Thanks 3
Cleaned the bugs and bean dust off the windshield and took a nice drive along the Rock River. Lovely day.
  • Like 5
Fall just getting underway here. Along LaSalle County 5 at the Vermillion River near Lenore Illinois.
Todays drive.
  • Like 7
On 8/8/2022 at 10:37 PM, MikeBMW said:
I just installed a Gen V Linkswell.
I like it, I have a wireless dongle for CarPlay and use it to connect my phone. Also, I can watch YouTube videos or NetFlix, but I never do that when driving.
That's why I use CarPlay when driving.
Mike - I just sent you a PM about this head unit. I'm interested in one and am curious what your experience has been like!
On 9/17/2022 at 7:41 PM, Stonewood said:
Can you go into more detail on how to run the CB audio through the Radio head unit?
What cabling is needed?
Does the cabling plug into the back of the radio?
Sorry for the slow response. Life has been crazy. The CB has a mono 3.5mm external speaker port. I used a mono 3.5mm to RCA adapter cable then a single female to dual male RCA Y adapter. That RCA Y adapter then plugs into the RCA Audio Input of AV Input on the back of my Pioneer AVH-4200NEX. I can then set my radio to AV and listen to CB on the trucks speakers. You can also use an AUX input on the radio but mine is used but the Maestro Interface for the radio. the problem you may run into with and AUX port is the CB outputs in Mono and a standard AUX port is stereo. The nice thing is I can listen to the CB while using Android Auto for navigation. AA will automatically attenuate the CB volume when it it giving you turn by turn directions. I can also simply reach around the back of the CB radio and unplug the 3.5mm jack if I want to use the CB's internal speaker.
  • Like 3
OOhhhhh. I see you plugged the CB into your Pioneer AVH-4200NEX. I am trying to determine how to plug the CB audio cable into my stock unit. There is no aux port on the face of it.
For a stock head unit you can use something like an iSimple IS31 FM transmitter. It will give you RCA inputs and basically t's into you antenna. You will need 2 antenna adapters as well to convert to proper antenna connector for you truck.
Stock radios aux input may be inside your center console (inside the jump seat, if you have that instead of the center console), or inside the upper glove box.
Update on the Gator Trax MX electric rolling bed cover and a bonus! :)
New hood wind deflector with lighting.
  • Like 4
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
