Finally got the new wheels and tires on my truck today.
On a side note, does anyone know of a good speedometer calibrator I could purchase?
Edited by steelerdude15
  • Like 6
I just went with the Rough Country calibrator because I didn't really want to get into all the tuning stuff. It was still a bit pricey at just over $200 but did what I needed. I have a Range AFM and between the 2 I'm happy. The RC calibrator can also compensate for rear end gear changes as well if needed. I have 275/60R20 tires on mine now from the stock 275/55R20. Surprisingly I set the calibrator to 32" tires instead of 33" and the speedo is perfect. Not sure why but obviously GM doesn't calibrate for the OEM 32" wheels for some reason...
Thank you. That is one I’ve been looking at.
Just a quick FYI, when I got mine, I plugged it into the truck and it wouldn't work. I don't recall exactly what message was but something about not working on my make and model truck. I thought maybe I got the wrong one. After further reading, I was supposed to hook it up to a computer and use the app to select my model truck as well as do an update. Once I used the RC app on computer, I selected the proper make and model and then after plugging in, it worked just fine.
I was reading that the RC calibrator also changes shift points. Is it a big difference? Does it make the truck more drivable or does it not make a big difference at all?
IMHO, I don't think it made a big difference. It seems to shift as it should. When I first changed to the 275/60's the speedometer read slower by a couple miles an hour than I was actually going and shifting did seem a bit off. Kind of hard to describe. After I did the correction, the speedo is pretty dead on as checked with a separate GPS and shifting seemed normal again.
Got all my chrome wrapped to paint match, pinstripe delete and black badges. Looks so much better.
  • Like 8
On 11/5/2022 at 8:04 AM, slj2008 said:
Look's Good - But i would add black rims ( But's thats me ) .
Drop the truck off to get a 4/6 and black 22x10’s tomorrow actually. I’ll post back.
Black and red is definitely a great combo.  Definitely don't need chrome in the mix to look great.
  • Like 6
Not sure if I'm going to keep them on long or not, but got a LED strip to run across the top of my grill. My son really likes it, so might keep it on for a while.. :D
SilverHolder™ Dynamic Car Hood LED Strip - Dynamic White
313919654_1261777964679334_4274136586673051439_n.thumb.jpg.3cfbb6bd24ba56e062029172ebfedc8f.jpg
Edited by jpinoy
video link change
has anyone swapped a (enhanced cooling)  NHT radiator into a non NHT truck?
a little research tells me the core size is the same but the tank is larger on one side so just wondering if it is still a direct fit or not or if i have to get a different trim piece or something, fans do not appear to be any different nht or not
On 11/3/2022 at 7:45 AM, Grumpy Bear said:
How many miles did the first driveline last?
The engine had 36k on it before it got pulled out. 10-12k of that was boost with about 12psi. Get beat on ALLLL the time. When I pulled it, there was 0 issue at all. I pulled it because I wanted to turn it up and I had some down time since it was summer break.
The trans however, was starting to let go in 4th gear. We were making 750-800 and it started to slip then grab slip then grab.
The TC clutches was also slipping and not holding power on the dyno. So we did a few run at the end and it only showed 745 with it unlocked on the last pass.
The stock driveshaft was switched out to a HD one from performance driveline just cuz i knew I wanted to make some power and stock one aren’t so good and holding power and speed…
Engine went back in yesterday. All that’s left is putting the whole front end back in and all the pipings for the intercooler. Ohhh and redo the trans cooler. Gotta move it back up front, having it under the truck with its own fan wasn’t all that great. Temp was in the 180-200 all the time.
Edited by CajunFries
  • Haha 1
Like ah pimp! Lol
  • Haha 1
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
