9 minutes ago, kwOH said:
Are you the same guy from tyf? Lol
i started shopping around for trucks looking at 14's and said F'it if I can afford a 14 then I can swing a 18 haha now i'm knee deep in payments again but it's ok I'll have it paid off in about 2 1/2 years
yep, lol you been hiding out over here?
Im everywhere there are gm vehicles lol, nice truck btw, I remember you saying you were going to get one.
almost went with a 19 but just couldn't find a standard bed at the right price, when i was shopping dealer near me put 84 2019's on sale every single one was a short bed ?
29 minutes ago, doubeleive said:
thanks! found one on ebay for $239, is there a oem plug in the grill somewhere or do I need to patch it in?
The kit I received, had a plug and harness with it.
ya, I see that it does so I assume there is a place to plug it in then? that's what I meant
Yes, to the left headlight assembly/harness, easiest one to access.  Little bit of a pain to disconnect, but possible.  One step of caution, be very careful when you insert the emblem wires into the connector, it is a royal PITA to undo and put them in the correct positions.
Edited by Ravenkeeper
Hey guys and girls, if you have a lower trim truck with no steering wheel controls and want to add them or if your looking to upgrade your instrument cluster to a higher trim like Denali and need to rewire some stuff then I have the videos for you. Chek them out!! Part 3 with the Denali cluster will be uploaded shortly.
Part 1
Part 2
  • Thanks 1
Part 1
[/url]
Part 2
Pm sent.
Sent from my LG-G710 using Tapatalk
Installed maybe 1/4 of the cupholderhero stuff. There are so many pieces. So many cubbies in the k2 [emoji23]
don’t pay attention to the crack in the arm rest [emoji20]
@Frankielozano214 can hook you up!
Sent from my SM-J810F using Tapatalk
2 hours ago, Frankielozano214 said:
Debadge the LT off my truck
did you have to polish any of it out?, I want to take off mine but it's nice gloss black paint so kind of hesitant
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
