Hello all!
I went to start my 2005 Sierra earlier and noticed it said "service air bag" on the odometer. Before calling the dealer to service it I was just wondering if anyone had any experience/tips/advice? I've never had a vehicle require that. I was just wondering about stuff like whether it will cost money to service it or anything like that?
Thank you guys in advanced for your input!
It will cost 1 hour of diagnosis and whatever they find wrong. Have to check codes and diagnose problem.
Sent from my LGL86C using Tapatalk
Been down this road too much in the past.. You have to have the codes. Not the ones from your hand held or Orielly shop reader, but the dealer code reader to find exactly what module has failed. Good luck!
You can use any tool that will read codes, dealer or otherwise, but that is only the starting point for diagnosis. Could be a hundred different problems.
I had this message on my 2008. Turned out to be an impact sensor (common failure). I ordered two from Rock Auto, changed both in about 15 minutes, and no more service air bag message!
You will have to buy an upper priced code reader to get the airbag codes. I just pushed the onstar button and asked for the code. Turned out to be a front impact sensor. Replaced both with the dorman brand purchased on line for 1/2 the dealer price.
Most readers out there will only read the engine codes when the light is on, not the ones in memory or airbags. Unless of course you happen to have the expensive one on hand and that is what you are referring to. Even the Oreilly/Advanced Auto stores readers will not read airbag codes. It sucks!
I had mine do the same thing on my 2008 Silverado...I fixed it by re-connecting the driver seat sensor which is located on the lower part of the seat on the right side near the console...for some reason it had pulled out from the connector.
Thanks you guys for your input!
I will start with checking the driver seat sensor but from what you guys are saying it looks like it has to go to the dealer. Perfect timing since I also cracked my sideview mirror (hoping to find a cheap replacement because I didn't realize how hard finding one with the turn signal was) and I am in the middle of moving. I didn't think about using Onstar for the trouble code. Too bad I don't have it anymore.
  • 5 years later...
I have a 2008 Chevy Silverado 1500 LS crew cab 4 by 4 I replace the right front sensor for the airbag underneath the radiator and my thing told me that that was the problem and I deleted all the codes and everything and it was working fine and then it came back on I have no idea what is going on
I’ve got a 2009 Silverado and this is exactly what happened to mine as well on the drivers seat. Thanks for posting helped me out big time. Not sure how it came undone but it was....
I had the alert "Service Air Bag" as well as the red airbag warning light in my 2008 GMC Sierra 3500.  It ended up just being a fuse!
I had first googled the problem which led me to replacing the oh-so-expensive front impact sensor.  After I replaced it the service lights remained on.  I went into the fuse box located in the engine area on the drivers side.  There you can read all the fuses.  There were two that said air'something'.  I pulled both and found one that was an obvious blowout by evidence of a small burn hole.  Ended up costing me $4 to replace the mini 15amp fuse. Better than the $170 for the sensor!  After I replaced it the service lights were off. Hope your solution is just as easy.
I bought a cheap ($150) Foxwell scanner and it said both impact sensors were bad. I bought one and swapped it between the two front impact sensors and it turned out to be just the driver side sensor even though the scanner said both. The bad sensor showed open when tested on an ohm meter. Saved myself $180 by just buying one sensor. They must be in series and if one goes it looks like both.
Edited by Steven Schnelz
  • 5 months later...
Although this post might be responding to an older thread, I'm hoping that my experience could prove valuable for future readers. I, too, experienced the airbag light issue on my GMC, and initially tried to fix it myself. However, I realized I was just wasting a lot of time.
Then I tried searching for other potential causes, then I stumbled upon an article titled "GMC Airbag Light" on the YOUCANIC website. This piece suggested inspecting the clock spring of my vehicle, as it could be a potential culprit, especially since I'd been having trouble with my horn and other steering wheel controls. Upon inspection, I discovered the clock spring wires were damaged, likely due to their age.
Subsequently, I replaced the clock spring, and was relieved when the airbag light disappeared after a bit of driving. I cannot stress enough the usefulness of the YOUCANIC website in my situation, and I strongly suggest that others might find it equally beneficial.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
