Just installed the 5100's on the front of my 17 with a Zone 4.5. I set them to stock height. I changed the rears a few weeks back. I used the strut tower on top of them.
This was a good upgrade, which is sad that a set of shocks with 5,500 miles in visibly good shape and rode that poorly. When I say poor ride I mean that Rancho has no decent uptravel control. The on pavement ride was ok, but the Bilsteins are better.
This wasn't a night and day difference for me, but definitely worth the mod.
Sent via Morse code
I suppose I should have asked, will the truck ride just as well on the stock setting as it would on the lifted levels?
I just wondered if the lighter/lifted settings preload the springs more than on the stock setting?
Seems I keep getting different opinions, so I'm second guessing everything lol
I have the Bilstein 5100 Ride Height adjustable shocks installed on the 3rd setting (2nd highest) and my truck is almost perfectly level. Only the most critical of observers would notice a very slight forward rake.
I really don’t like the look of a truck with a higher front than back and of all the trucks I’ve seen with 5100s on the highest setting, the front is just a bit above level.
Regarding the spring compression, quality of the ride and installing spacers, the thread below has a lot of useful info. I cannot comment if the truck rides as well on the stock setting as the third because I’ve never had the Bilsteins on the stock setting. Compared to the Rancho shocks on the stock setting vs the Bilsteins on the third, the Bilsteins ride much better.
https://www.gm-trucks.com/forums/topic/183204-consequences-of-a-15-level-lift-on-a-sierrasilverado-1500/
So are the 6112's a lost cause now?
Talked to a Bilstein rep at the Offroad expo in Pomona this weekend. They have them tested on the 5.3, and should be releasing "soon". They were surprised when they didn't pull up in the website
I called them two weeks ago (they are close to my work). Guy said this fall. (fall is now) so don't know. need shocks and need 2" lift to run 33's. Want a premium shock and the only other (more expensive) good option seems to be the Icons. I really want a shock with a larger body and 5/8 shaft. Not enough positive reviews on King or fox entry level 2.5's and longevity.
Bilstein provides the best durability for DD, and they don't seem to loose performance much over time or miles in my experience where a King or Fox will need regular service to maintain performance (I read they recommend service intervals of 30k mi or so).
Agreed, i was looking into the Fox 2.0 and 2.5's and neither of them seem to have very good reviews. I find it a bit weird the 2019's are a new platform and they still don't have the 6112's for the 2014-2018 trucks, fingers crossed!
See what you think about this kit.
https://www.halolifts.com/GMC_c_149.html
I run the Rancho RS9000 series on my vehicles.  They are an adjustable shock that is very durable. I had a set on my 06 Jeep Rubicon that I trailed  a lot. Shocks never gave me an issue and rode much better than stock.
I had a set on my 12 GMC 2500 after adding a Zone lift to it. The Zone shocks rode really bad.
Added the Rancho RS 9000's and it literally was a night/day differnce and then some!
I rode in a truck that has Bilstein shocks.  To me the Rancho RS9000's rode a lot better.
Edited by churchy1313
The 9000's are adjustable so they can be dampened down quite a bit.
Not much of a fair comparison with the 1 set valving of the 5100s
Longevity is questionable. The adjustment twist knobs on these do not seem to hold up well.
Out of the 5 sets of the Ranchos I’ve had
i never had a problem with the knobs.
i had 2 sets for over 4 years with no issues.
on the Jeep, I turned the knobs a lot for different terrain, never had an issue.
im getting a pair of rear ones installed this week with a zone 4.5” lift
I apologize if this particular question has been answered but I've searched and searched and haven't found exactly what I'm looking for.  I'm running stock tire size and have no plans to run larger tires.  I put 5100's all around a couple weeks ago and love the ride at the stock setting for the front.  I came from a '09 Sierra that had more ground clearance than this '18.  I have 9" at the air dam and 10" to the step rails.  The dam on my '09 is in the backwoods somewhere and it was higher.
I don't want a full 2" lift and am contemplating moving the fronts to the .75" or 1.25" setting and adding another inch to the rear.  I've seen numerous posts where the 1.25" setting is more like 1.5".  I've found two posts where the poster has theirs at the .75" setting.  One said it gave .75" and the other said 1".  If it's 1" I'll probably move to that setting.  I'd really like the 1.25" if that's what it really does.
They look promising, but not much history or info on Halo. From years of off road experience I found that it's best to go with the company with the best reputation for performance and quality(properly valved shocks combined with the right technology make a radical difference). I've seen enough on ICON to be convinced that they are legitimate and have a solid understanding on how to create a true high performance shock.
I'm a fan of King actually, just for the cost proposition of even the entry level fronts ($1600) from what I've seen. The added maintenance schedule, and no digressive valving for a mostly street truck with the occasional off road not sure they are the right fit for me. King quality is second to none, just everything I've seen with them (Buggies/utv's) always needs them re-valved or rebuilt after a season or two. Which is cool for a Hi performance toy, not a daily driver IMHO
To me Bilsteins are kind of generic, but they provide a lot of value & as long as they don't leak seem to last much longer than any other shock I've seen( on cars I've mostly had Bilstein and Koni). I just want to buy once...
For a street driven truck they don't need to be rebuilt that often. Once every 60-70k miles would be fine unless you're coating the shafts with dirt/sand all the time. Which is exactly the reason they need to be rebuilt so often on an Offroad vehicle. Street vehicle, not so much
    JimmyB4
    JimmyB4
  • Who's Online   5 Members, 0 Anonymous, 626 Guests (See full list)
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
