Yea I think that makes sense. All the force goes through the shock/lower control arm instead of through the balljoint/upper control arm. Still not a good idea to hammer on the shocks that hard. It would probably wear out the seals and stuff early. Not that you ever do that much on the road.
I went with the Eibach leveling kit so I am at around 2.5in level so I definitely wanted to get some upgraded UCAs to help the angles. I don't think 1.8 inches is gonna hurt anything but I just don't like that the upper balljoint is held in by a piece of sheet metal on my truck. If I had the cast steel or aluminum I probably wouldn't have switched or waited until my baljoint was worn out to switch
On 2/16/2020 at 8:59 AM, Jdub289f said:
That’s good the hear! With my 5100s it felt more controlled but the stock coil doesn’t seem to be good at all. Almost like it’s maki  nag the shock do too much work. I’ll have to get the 6112 kit when my funds allow it. Should be an easy swap without having to align it since I already have the 5100 adjustables on there in the max height.
actually that's what you want if you have a good shock.....spring just supports the vehicle and shock is responsible for dampening, spring shouldn't get in the way of shock doing its job....if you have more dampening maybe can get away with lighter spring.....but yeah you want the shock doing most of the work....
Ok needing some help deciding. I have a 2014 Sierra crew cab 5.3L z71. Right now I have a 2" level in front that mounts under the strut (1" in thickness for 2" lift). Nothing in the rear. I have 275/70/18 on stock rims. No rub noticed on pavement or off road.
I have 1-1.25" of rake and I like the way the truck sits. But I want to change the shocks to either the bilstein 5100 or eibach pro truck sport. I'm keeping the stock springs and losing the spacer.
I know what the literature states for what sort of height increase to expect. But I'd like some real world #s. I've read this thread and some seem to be getting more lift than the reported #s. Please let me know your rake with this setup. Thanks!!
the eibach kit with eibach spring sits higher than same kit with stock spring....i believe its about 1" difference more lift....so when your reading stuff note whether its stock spring or eibach….both work on same kit.
Edited by Dunn
Yeah for sure, I'm talking about with stock springs. Just changing the shocks.
1 hour ago, BBinnj said:
not seeing that anymore- showing at $702.99 now...
Just checked. It is.
Well after as much reading as i could do on this Thread I've got everything set up to go on this month on the 26th.
Items are:
-6112 kit for front
-5160's rear
-Kryptonite UCA's (KRUCA13)
-Fuel Blitz 18x9 +1 offset
-275/70r18 Kenda RT
-1" Shackle for rear
-Zone trim plates
2018 Silverado w/ 13k miles
Items are:
-6112 kit for front
-5160's rear
-275/70r18 Kenda RT
-Zone trim plates
You likely won’t need the trim plates. I would hold off on installing them until you get the tires put on
I was planning on that originally but these tires run large for a 275/70r18 at 33.45x11.23. Plus i do plan on taking it offroad so just would rather remove any risk of rubbing at the same time as getting the rest done.
Quick picture after picking it up, will take more tomorrow: 6112’s and 5160’s
Looking forward to more pics? How did the trim plate install go?
    • That's not what I was talking about.   I have not seen it specifically documented that bottom of the hatched area equates to "1 quart low".    I've never measured or compared a dipstick reading at the bottom of the acceptable range, added 1 quart, took a new reading and it be exactly at the top of the range.   My view of the manual is if it is BELOW the mark, add one quart at a time until the level is within the hatched area, 1 quart could put it 1/4, 1/3, 1/2 all the way there. I don't know, none of mine have been BELOW the mark to require adding any to find out.   However, if over 400 miles it takes multiple quarts to keep it in the hatched area, yes, that is a problem.   EDIT: None of my vehicles have ever been to the bottom of the range, every check shows them give or take somewhere on the top half of range. (I might even challenge my own memory and say at worst the top 3/4s.)   Never to the bottom, much less below the "add" mark, so I've never added 1 quart to see how much it moves the level up the stick. Circling back to my point, the volume coming out is less than what everyone suggests my dipstick readings should be indicating.    If from the top to bottom mark of the hatched area equates to 1 quart of oil, I would see the dipstick reading (on every vehicle I've touched in the last 30 years) be at the top of the mark when I fill with new oil and be at the bottom just prior to changing; based on what I am measuring in the drain pan. However, the dipstick readings are NOT showing that amount of drop. See above.
    • Anyone have any experience with adding the autosense module to a high trim suburban/tahoe?    2026 Chevy Suburban High Country - Did not have the "tech pkg" but does have the High Country Deluxe pkg. Absolutely wild this is not a standard feature.    OEM route - if it's already a powered hatch, has anyone tried to install the module for the hands free and tried to get GM to reprogram the BCM?    Aftermarket route - if OEM is impossible or too much of hassle, does anyone have any experience with aftermarket hands free sensor options?     I know Ensight Automotive does the conversions, and I've read a little about ISS Automotive. Any experience with these options/vendors?
    • I purchased these two 6 quart boxes of Mobil 1 Synthetic LV ATF HP for my 2018 GMC Sierra with the intent to change the fluid, but I never got a chance as I sold the truck in 2021.  Both boxes have been in my garage ever since and are new and have not been opened.  Asking $50 for local pickup/meet in the Western PA area.  I can probably ship, but that would be at the buyer's expense.
    • Unfortunately the most I can speak to how everything was reassembled is that I have used Joe quite a bit and he's always proven knowledgable, capable and honest. As to individual things he did I just can't say. I do know that he was under a time crunch to get all of this done and personally if I were in that situation I know I would be more susceptible to making minor mistakes. Though he did tell me he took the truck on an extended test drive after buttoning everything up and it did not throw a code for him.   With everything I know about the situation and as a layman, if I had to hazard a guess I'd say there's a non-trivial chance something minor that was overlooked. I was kind of hoping to narrow it down to a smaller subset of possibilities so I could have a more useful conversation with him.   A DOD-delete cam did come with the kit and the pictures Joe provided of the job indicate it was installed.   To my knowledge all O2 sensors are OEM. I purchased the truck at 75k miles about a year ago and the sensors were never replaced under my ownership.   On the intake gaskets, I supplied the parts and I did specifically purchase and give Joe all new gaskets to install. Anything that was indicated to be one time use, I purchased a new one of and supplied to him.
    • Double trust, huh?   I hear ya.   Side note, one can get trust off the internet. I belong to a Pontiac message board such as this. I sold a complete  running Pontiac 455 that I built in the late `80`s. Most won`t touch a complete engine. Especially an older one. The dude offered me $500 more than I was asking. He paid the truck freight to Lubbock TX. All I did was build a crate for it.   I told the dude he was ballsy. He says, "I trust you".
