Thanks.  What UCA did you use?
Kryptonite KRUCA13 (for stamped steel and aluminum UCA trucks)
15 minutes ago, 3tspapat said:
Read his question. Required vs optimal is not the same.
I can only go off what I've read.  There is more than one person / company saying due to the design of the stamped arms they are not safe to be used at the 1.8-2.5" lift. The ball joint can separate.
In my opinion, unless they're wrong, that makes them required above 1.5.
How many different types of upper control arms were produced? I know I've heard of aluminum and stamped steel but mine on my '15 4x4 Max tow look to be cast and I believe steel. Just curious.
3, forged steel, aluminum and stamped steel.
Hello.  My dealer charge $350.00 for labor to install the Blistein Adjustable Shocks plus $120.00 for alignment.   This a good price for install all 4 Shocks.
If possible change the back two yourself, very simple 15 minutes and your done. Only need basic hand tools. Could save you a few dollars.
Sent from my SM-G973W using Tapatalk
Good price. You most deffinetly should get the alignment after.
Sent from my LG-G710 using Tapatalk
I am ready to place an order.  But I have some questions:
1. How reliable they are?  Better than the ranchos
2. What setting height adjustment is recommended just to level the truck remove the rake.
Thanks,
Thanks,
Better in terms of no pogo bounce in the front. Little stiff but after long rides they break in a bit.
Max setting still will leave a rake.
How long you have them.  DO you have a good experience and what height adjustment you have?
Thanks for your help.
On the time frame idk exactly. That being said I posted in this tread when i got them months ago.
Maxed out as stated they are a bit stiff. Theres a thread about bils and a bumpy ride that suites these very well in terms of how stiff. Its very weird in that some have zero complaints while a few who are outspoken lay the facts on the table.
If I had to do it again. 6112s, king or the like high end.
This is one of those do it right the first time things folk dont talk about enough. I say save your funds spend the extra and make your money worth it and go the 6112 and any other spring then stock. Thats money well spent. Bils are for the guy on a strict budget who doesn't mind a stiff ride. Sure you can change to p rated tires, but wait for it... Pot holes and nails will become close acquaintances[emoji16]
Bit long winded, but I so wish someone said this before my purchase.
  • Like 4
Thanks,
Bilsteins are very reliable and mostly seem to last forever. I installed my 6112s and 5160s last September and am still happy with them. I now have about 8k miles on them. They seem to get better with some use.  I like them better now than when I installed them and I’m running E load range KO2s at about 60psi most of the time and am at the top setting.
Currently running 275/70/18 Ko2 on OEM suspension for the last 50k miles. Shocks are toast now; never had a rub. Anybody running 285/75/18 (OEM wheels) with the 6112? That's a close to 35" diameter tire.
Can’t remember from when I installed the 5100 but I want to lower the front shock to the bottom ring for stock ride height so I need to take the spring off for that? Wanting to do that tomorow but need to know if I gotta get a spring compressor first
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
