Can’t remember from when I installed the 5100 but I want to lower the front shock to the bottom ring for stock ride height so I need to take the spring off for that? Wanting to do that tomorow but need to know if I gotta get a spring compressor first
Yes you need spring compressor.
I have a :
2017 GMC Sierra 1500 Crew Cab RWD
I’d really like to run a 35 but I am not a big fan of 4+ inch lifts. Unless there is some sort of coilover UCA combo I am missing. So I guess I’ll have to settle for something in the 33 range, ideally 305/70/17...Have people gotten away with that tire set up with the 6112 shocks?
On 4/25/2019 at 3:30 PM, Sierra Dan said:
4600 and 5100 are built identically on the internal side other than a longer shaft for the 2" of lift.
Not looking to start something here but as of today (maybe different in the past) this is false information. I've called Bilstein twice now and spoken with two different dudes who have confirmed that the valving is indeed different.
They keep their valving specs on lock down but they confirmed it's different and that the 4600s have softer valving, by how much? No clue!
...SOOO for someone who isn't looking to increase height on the front (which is clearly the minority) 4600 is probably the way to go!
Ok starting to go cross-eyed, I have a '14 GMC 1500 Z71, having Bilstein 5100's put on Thursday, planning to go with the highest setting, what's the biggest tire size I can go without rubbing, or with minor trimming on the factory 18's? Kind of eyeing 285/65/18's or 275/70/18's in BFG AT2 or Goodyear Duratracs
I have LT275/70/18s, no lift Ko2s and no rub. 2014 silverado CC 4wd. So you should be able to do at least that.
I think I want to go somewhere between stock rake and level. Anyone got pics using the 2nd notch? Thanks.
Thanks, went with the 5100's at the highest notch, and the 275/70/18 BFG KO's, only rubbing is one right turn at full lock, I just need to tie back the inner fender liner and it looks to be no rub after that, very happy with the ride and looks, a little stiffer than stock but I always felt the stock ride was too soft anyway, should have done this from the get go, with a tape measure it's 1" higher in the rear after the install
Edited by Ryan A
I went with the 2nd notch.  I think looks good and I wanted some rake.  The truck ride better than the rancho factory shocks E1850EC0-6284-404B-89A8-2385D19E3CA2.jpeg.d12faf0cd2bd6ec6127f9111cf74922b.jpegks
Thanks! Looks great!
Hey everyone, I need some help figuring out what to do with my truck:
2017 Z71 CC 90,000km
Installed Airlift 5000 at rear last year
Front end now looks stupid low, and front suspension feels dead. Rear suspension feels just fine now with the air bags.
It seems like the 5100 will be the best bang for my buck. Should I install a full kit on all 4 corners, with new coils up front? Can I just get away with installing the 5100 up front?
Anyone know of a good deal for a set of 5100’s right now? Looking to buy in the next week. Thanks.
It won’t be quite within the week but probably in about a month. I’ll be taking mine off and putting 6112s on. They have about 20k miles on them so I’ll do $120 for the pair
Added Bilstein 6112s on the highest notch today. Rear has 5100s and 2.25” blocks (1” of lift). It turned out exactly like I wanted it to be.
affb9d5190a9c38ff9cfc01ece3c909a.plist
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 692 Guests (See full list)
