Rocky Ridge Callway Silverado Will Blow Your Mind - Motorweek
John Goreham
9/10/2015
Admit it. You have always wanted a Silverado with the engine of a top-spec Corvette. It isn't just a want. You need it. This may be your ultimate Silverado if you feel that way. 560 hp and 553 lb-ft of torque from the 6.2-liter supercharged V8. This Callaway is also ordered at your local Chevy dealer and it comes with a full-factory 3-year warranty.
The modifications don't end under the hood. Rocky Ridge adds a four-inch lift and 20-inch wheels with 35-inch tires.
We can keep on yapping about this amazing truck, but the folks at Motorweek did an amazing job of capturing the truck's personality. This is no toy. Watch how John Davis and the Motorweek team tack the truck to see just how buttoned-down this thing is.
Pass. Just bring the 8.1 back and update it, make it so I don't have to jump through hoops to get a real bed on a truck, and rims no more than 18" and I'll be happy. That amount of power plus the lift is just asking for me to finally wreck a vehicle. As usual though, to each their own.
Still faster than stock, but not going to reach its potential with big tires and a lift. And it's $86,000... Could have a nice Duramax that would do everything better for that price....
After looking into this truck a little more it actually comes with a full suspension upgrade which is nice. Aftermarket coilovers instead of blocks and spacers. Still probably way over priced but at least they are lifting the truck in a quality focused way.
Edit: Holy crap this truck is $86k!?!?! Insanely over priced.
Why not just swap the engine for the 630hp Corvette LT4 engine or the new 2016 Cadillac CTS-V engine? It would be much better feature than tuning an existing engine
You're off by about $20,000. Adding a blower and using the handheld is only about $6,000.
86K
You can buy a Vette truck and trailer and upgrade all and still be around 100K
Ryan
I know it is cheaper to upgrade your existing engine but the internal parts will not be as strong as the stock LT4 engine. I think the $20k LT4 will give you horsepower and peace of mind.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
