Check Out Chevy's Silverado Red Line On Display At SEMA
John Goreham
10/22/2015
Ahead of the SEMA show coming the first week of November, Chevrolet has teased some images of the Red Line Concept cars it plans to display. The Silverado's Red Line treatment includes exterior styling changes all based around a Silver Metallic exterior color. The biggest modification is that the roof gets a Charcoal black treatment. The Silverado also has a great Satin Graphite front hood color. The rims have gloss red patches, and red is used sparingly throughout the trim to offset the satin elements. We love the look, but wonder how much heat a matte finish charcoal roof would add to the interior of a vehicle. What's your take?
Too bad it is paint on the wheel and not a fat red brake caliper
...and the REST of the specs might be?
Or is it all 'surface' treatment?
I like the roof.
the rails own any vehicle, trucks are dramatic. when a chevy drops thermally local, the rockers are gone within months..doesn't know how to come back out of the routine..
black is one of the best colors for the roof. I hope it gets good and hot.
To answer some of the above, yes, the Silverado Redline Concept is primarily an exterior graphics change. Chevy did put a variety of parts from the existing Chevy Performance catalog on the show truck including:
◾Air intake and exhaust kits
◾Brembo front brake kit
◾22-inch wheels (with custom red accents) and center caps
◾Black bowtie kit
◾Black-chrome exhaust tip
◾Assist steps and cargo bed extender
◾GearOn™ cargo rings and cross rails
◾Hull-a-Port mounts and straps by Thule®
◾Floor liners.
It has TONS of potential but would want to see it in person for the final judgement. GM has some awesome ideas sometimes, then other times not so much. Would it bake the interior? In my neck of the woods...not so much. In Phoenix.....you could fry bacon in there LOL :tumbleweed:
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
