I just bought a Sierra all terrain x and have removed the light bar/ roll bar. I'd like to sell it and price is negotiable. Text 508.509.4036 if interested. Also looking forward to learning from this site. Does anyone know what needs to be done to get cab brake light working now that light bar is removed?
John
I keep waiting for that sport bar to grow on me......I loved the way they looked back in the day
I am looking to buy one of the sports bars. I have about $4-500 to spend. My dealer has one still trying to get them to give it to me for that cheap since GM pays alot less for those from the factory. Let me know
No brake light with my sports bar, but there is a hole. Recon and factory light will not fit. Did the sports bar come with the brake light?
I put the rail under the forward mounts notched it for the rear mount. Just need to add a bead of silicone to seal it up
Hey SF GMC, would you be able to post a picture please of the inside rail at the mount? Does it need to be cut, or is there enough clearance for the bed roll to roll on properly? My hubby and I just purchased a Chevy Silverado with the sport bar, and need to install a tonneau cover. We like the look of this one that you have installed...
I so want one of these for my Sierra but of course my wife thinks it's ugly.
Does GM make one for the Sierra?
Your wife has good taste
X2... pics of the underside if possible. I bought the Revolver with the same idea in mind. I notched the topside, not sure if the underside needs the same.
So i went ahead with this install. The rail on the top side AS WELL AS the side that marries to the inner side of the bed rail also needs to be notched. Not to bad at all, did it with a dremel tool. I will post pics later on.
very nice, well fitting cover when its all said and done.
I just picked up my new Sierra All Terrain X last week with the sport bars....so I am just trying to sort out what the best bet for a bed cover is now. I really like the look of the sport bars and a bed cover is essential for us.....not sure what route I want to go yet. I`m surprised GM hasnt come up with a solution yet.
I just did a BAK Revolver X2 with some minor mods to the rails around the rear sport bar mount. Came out very good.
If you could post any pictures of the notching you did that would be really appreciated!
Yea I would like to see how you did that as well. How are you sealing the sides around where you cut for water leakage
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
