2017 Chevrolet Corvette Grand Sport - Images and Specs
John Goreham
2/29/2016
Imagine yourself towing a Corvette behind your truck on the way to a track day. If this is your idea of fun, consider a 2017 Corvette Grand Sport. This is the one that the folks at Chevy have breathed on to make it dance on the racetrack.
The Grand Sport is all about lightness and cornering. Chevy calls it "A pure expression of the car’s motorsports-bred pedigree." This track-'Vette starts off with the LT1 V8 engine rated at (343 kW) 460 hp, with dry-sump oiling system and active exhaust. Both the rev-matching 7-speed stick and 8-speed paddle shifting automatic are available, and the auto has a Grand Sport-specific calibration. For the first time, the Grand Sport can also be combined with the Z07 package. When set up this way, the car can corner at up to 1.2gs. Chevy says that the new Grand Sport with Z07 package is within a fraction of a second of the prior ZR1's time around the Milford Proving Ground.
Here are the highlights of the package:
◾Michelin Pilot Super Sport summer tires: 285/30ZR19 (front) and 335/25ZR20 (rear)
◾Specific Grand Sport wheel design: 19x10 inches (front) and 20x12 inches (rear)
◾Brembo brake system with (355 mm) 14-inch rotors and six-piston calipers in front and (340 mm) 13.4 inch rotors and four-piston calipers in the rear
◾Standard magnetic ride control, specific stabilizer bars and unique springs
◾Standard electronic limited-slip differential
◾Front Fender Inserts, Z06 Grill, Widened Rear Fenders
◾Optional Grand Sport Collector Edition features an exclusive Watkins Glen Gray Metallic exterior with Tension Blue hash-mark graphics
◾Available Z07 package adds carbon ceramic-matrix brakes and Michelin Pilot Sport 2 Cup tires.
The Grand Sport will be on sale this summer in the U.S. and the Grand Sport Collector Edition in the fall. Chevy plans to offer the Grand Sport in Europe as well about three months behind the U.S. inventory allocations.
post-139450-0-42427500-1456846346_thumb.jpgpost-139450-0-29088200-1456846332_thumb.jpg
post-139450-0-74253600-1456846272_thumb.jpgpost-139450-0-46101500-1456846233_thumb.jpg
Nice car but I always hated those stripes on the grand sport front fenders as they look out of place. If I had that car that would be the first thing I would get rid of.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
