Where was your baby born?
After reading a lot of these posts it seems that some owners like myself got a great truck out of the box and yet there are lots of complaints of vibrations, leaks, poor fits and other problems. Before I bought baby I test rode many other Silverados to get the pick of the litter and none of them exhibited vibrations or other apparent problems. This contrasts with the '07, '12 and '13 Avalanches I've owned over the years which developed mechanical issues and worse, numerous leaks soon after ownership. I always attributed the leaks to the crappy sealant and sloppy way the panels were sealed....one even had a chunk of sealant the size of your fist globbed under the bed mat which certainly wasn't done by any robot......in contrast the sealant used on the panels of the Silverado, Traverse and especially the Malibu is precisely applied. The main difference I could see is the the latter were manufactured in US assembly plants, while the Avalanches (like many Silverado/Sierras) are manufactured in their Mexican plant. Noticed an article stating that GM is moving a portion of their Silverado 1500 production from the Silao, Mexico plant (3 as first # of the VIN) to the Flint, MI (1 as the first# of the VIN) plant were my Silverado was born.
http://www.trucktrend.com/news/1606-gm-reportedly-moving-more-truck-production-from-mexico-to-michigan/
Every one of those Avalanches leaked like a screen door in a submarine, door leaks, sunroof leaks, bed leaks, tailgate leaks, CMHSL leaks, roof rack leaks and my favorite failure to properly seal the roof panels.
Could be that the reason GM's transfer is for political reasons like the article theorizes or it could be that the GM 1500 series trucks (and the 8 speed trannys) out of the Silao plant are coming out as crappy as my Avalanches. That is primarily why I chose a #1 Silverado and why I chose the optional US built 2.0T in the Malibu.
Might be of interest when someone posts that their new truck is a lemon that they indicate which plant it came from.
  • Replies 54
Mine came from Indiana, fort Wayne plant.I bought mine had 7 Miles on it. I never even test drove it.lol went out on lot and picked the one I liked. I guess I got a good one because mine has 0 issues. Plus I did not discover this site until after I bought it. Mine is 2015 GMC Sierra z71 sle.
1st digit is country code, but not plant
1st digit 1=us, 3= mexico
But the plant location is the 11th digit.
F= Flint, Z= fort Wayne and G= Silao
FWIW, the Avalanche was base on an SUV frame, not a pickup frame.
My truck was built in Mexico. - fit and finish is excellent and runs flawlessly. I prefer my vehicles to be assembled in the USA or Canada but not because of quality concerns.
This explains why my blinker spontaneously turns on every time I pass a Taco Bell...
Flint, Mi, about 5 miles down the road from where I was born. Drove by the Flint plant about 2 hours ago on my way to work, the back lot is full of new truck waiting to ship
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
