So I finally gave up on waiting for a fix for the 8 speed and its many mis-behaviors and had my truck tuned by a local custom tuner that has been working with LS/LT motors and transmission tuning for many years. He plugged in his laptop and rode with me for over two hours. The truck is a new animal. Great at shifting and the engine acts like the beast it should be.
My truck is a 2015, 6.2L 8 Speed, 23,000 miles. It has always had the low speed clunk and recently developed the shudder, especially in 8th at steady state highway speeds.
Here is some of what was done.
AFM shut off, Torque Management shut off, Variable cam timing adjusted to performance lift, 1st gear set to hold until 11 mph, higher shift pressure for next few gears, torque converter set to 0% slip, raised speeds for converter lockup especially in 8th. Other parameters were adjusted, but these were the main ones.
Some of what was learned.
The TC was slipping too much when trying to lock at light load (half in half out) causing the shudder. It was also trying to lock at too low of a speed/RPM almost lugging the engine (again most pronounced in 8th). No more shudder in any gear. It does take a decent speed (over 60-65 to lock up in 8th, but once locked it will stay locked below 60 unless I kick it in the pants or the load increases). As most of you experience, 1st gear was trying to get to third as quickly as possible. Now I can move through parking lots without trying to throw a U joint. There were more learnings but these 2 are the big ones.
I will probably lose a bit of MPG in town driving (I am fine with that) but the 60 mile trip home at freeway speeds netted 20.1 MPG ... not enough loss to consider if any. Performance is incredible. I floored it from a stop a couple days later, and had to back off to preserve the tires as it started roasting them. Shifting at full throttle was impeccable. Longevity (as long as I dont drive it live a sports car) theoretically will be better than it was with all the clunks and shudders. I am thrilled with the results.
If any of you live near Van Buren Arkansas, and are interested I will pass on the contact info.
Man that sounds awesome. I feel like this 6.2 is capable of so much more. I also have an 8speed (2017 Sierra). I recently had the shudder issue fixed with a transmission flush at the dealer. But I would love for the truck to wake up a little and act like a 6.2 and not a 4.3. I’m up in Fayetteville,  so van buren is a short drive for me.
I had my 6.2 tuned about a year ago.
The power never gets old. It never feels slow. I have no idea how a measely 420hp pushes 5500lbs so hard.
btw, you haven’t lived until you, put it in 4wd auto, turn off traction control(important), and launch it. Switch back to 2wd right after the launch (it just decouples the clutch diff, not bad for it at all)
Man I want a tune so bad. Gonna be years before the warranty is up though.
Sent from my SM-N910V using Tapatalk
Search for evidence online that a truck’s drivetrain was denied a warranty claim because of just a tune. I couldn’t find any.
I know man. I just don't want to take the chance. Too much of a p*ssy I guess. Never bought any vehicle brand new before.
  • Sad 1
My first as well, im super duper cautious
I thought it if like this.
risk = worst case scenario = lost engine and trans, not covered under warranty, cost to replace $13k
chance of either one if them happening, realistic is likely 0.01%, but lets say the chance is 1%.
If you have a 1% chance of losing $13k, you can look at it as your tune is costing you an extra $130.
Just go with a reputable tuner and live a little. The truck is so much better. The risk, calculated accounting style, shows very little actual risk.
I've got a highly modified camaro and would take it in for warranty work no issues.
  • 7 months later...
Could you post the contact info please
With these K2's it seems like you can have all this crap tuned out and have a proper performing one, or you can not tune it, keep the warranty and fix broken parts, aids and driver nannies. 75% of the problems these trucks experience are around the AFM and trans tuning, so why not have it tuned by someone who knows what they are doing? Because let's be honest, you can't really screw up the tune, GM did a good enough job of that on their own.
Now my 6.2L is acting up and vibrating in a pulsing pattern, I know full well it is going to be a AFM or torque converter issue. If it wasn't for the botched drivetrain tuning, these would have been the best trucks GM ever made. For now that trophy will remain with the 07-13's IMO.
  • 2 years later...
Hey man, I'm up in Bentonville and looking to get my truck (2018 6.2l, 8-speed) tuned by JP. I was wondering if you could provide an update on this, as to how the tune has performed over time... any issues or things worth noting? Thanks in advance!
I know you only have 23k or so miles on the truck but now would be a great time to change out all the transmission fluid. This way the transmission is fresh so to speak and any wear-in material from the poor performance before can get changed out.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
