Love these new 2500 AT4s. Wish they would have given it a little 1-2 inch as well. Like the ford tremor or ram power wagon.
Thanks man.   Now I just need to find a way to upgrade my stereo from the crapper IOR to the IOS or IOT model.  Anyone in here know how to pull that off please please please let me know.
EDIT:  Last 2 trucks I have bought I have always thrown that ultimatum in at the last second, give me leather for free or I walk, worked twice now and this time got AMP steps too and for only 400 bucks on my end.
Great looking truck! I talked to a guy at Infotainment and they are in the process of making a upgrade available. He told me they hope to have them available at the beginning of 2020.
Thanks man. Ya I talked to them too, problem is that they are going full bore adding the Nav piece too which will probably drive the price to $1,699, alot to pay for $358 dollar radio.   All I want is the IOS version which is everything GM offers (custom settings per user, download apps, over the air updates...) minus Nav.  I will keep my fingers crossed though.
Edited by Ktoonsez
They put a 2” lift and 34” tires on the 2500 AT4. The pic of my old truck next to it has a 6” lift and 35” tires. You can see the AT4 isn’t too much lower. Would have liked if they had it sitting a little higher to fit 35s stock. I think they would rub if I put them on without modification.
On 10/20/2019 at 12:01 AM, 808 HI said:
After a little over a month of owning, finally got to take some decent pix.
I’m normally more of an off-road looking truck guy...but dang, your truck looks awesome! Perfect combination of color, wheels, and stance.
57 minutes ago, THE SILVERADO said:
Gorgeous!
Appreciate the kind words. I lucked out on the wheels having similar color to the truck and glad that I went with the 40 series instead of 35, made the whole setup look proportioned on these new big body silverado.
More details if you don't mind.... reps or take offs? 285/40s? Lowering shackles or stock suspension? 2x4 or 4x4? Truck looks amazing, best looking T1 I've seen so far. I'm trying NOT to go from my 17 to a 20 RST and you're not helping ?
24" Reps, 295/40 with Atturo AZ800 tires. 2x4, stock front, rear Maxtrac lowering shackles set to 2", pretty leveled all the way around within +/- 3/8". Would love to go to a 2/4, belltech has a kit coming out so we'll see. As far as best looking, I appreciate u think so but I'm sure theres others here that's way better looking and modded out. I'm also trying to put the RST trim to use lol.
2019 Silverado Crew Cab LTZ
6.2L V8
SCA 6 Inch Suspension Lift System
35 Inch Toyo Open Country Rt
SCA 22x12 Wheel & Tire Upgrade
Front & Rear: 22x12 Offset: -44
SCA Logo Red Brake Caliper Covers
SCA Speedometer Calibration
Performance Exhaust Upgrade
Black 5 Inch Oval Wheel-To-Wheel Side Steps
SCA Bolt-On Style Fender Flares
SCA Chevy Hood Vents
Premium Quality Black Widow Exterior Badging
SCA Performance Windshield Snipe
Black Widow LED “Puddle” Projector Lights
Red LED Interior Lighting
Black Widow Stitched Headrests
Painted Interior Trim
  • Like 7
Little update on my “non-blacked out Trail Boss”. Grabbed an overstock bumper, a take off grille, and sold my trail boss 18’s for High Country 20’s. TB suspension with a 1.5” leveling kit. 285/65r20 BFG’s. I love this truck!
  • Like 9
Your updates are right up my alley... debadge, tint, clean it up and make it look like nothing happened. I couldn't even tell those were 24s lol... thought they were 22, hard to tell on the T1s. The look is definitely working!
Looks good! I’m getting an LTZ, and I’m torn between putting just a leveling kit and 275/65r20...or getting the trail boss kit and a leveling kit like yours, and doing the 285/65r20. Your truck makes me want the 285s!
On 6/17/2019 at 1:37 PM, PabloK said:
285/55/22
Nitto Ridge Grappler
Best tires you can get if you want a nice ride with an aggressive look... read some reviews.. it’s clearly the industry leader for new hybrid truck tiresaa0507d814fe6b8f762f3912e9a647bc.jpg512023c4afd53742d00e49ae097687be.jpg1c849b466c0305120049242c9ab85af3.jpg6f97e6378b095f1f4c3edacdc5cbdcaa.jpg
Love those rims on your truck.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
