Had my AT4 for about 6 weeks and today I noticed that whoever applied the GMC to my MultiPro must've been drunk.
It's about 1/2" off center and tilted down to the right. Not a big deal since I'm switching to blacked out emblems. Became more noticeable since I removed the Sierra badging.
Edited by FDHog
On 6/14/2019 at 8:14 PM, wizard4878 said:
The 2019's must sit quite a bit higher than the 2016's ,  because my 2019 slt (stock ride height) only clears my 7 foot garage door by about 2 inches at the shark fin, so I'm sure if I put a 6" lift and 35s on it, it would hit somewhere about 5 to 7" down on the windshield
I think something must be wrong if it’s that tight with a stock ride. Or they snuck a 6” lift and 35s on your truck and didn’t tell you! :P  I also have a 7ft garage door and am parked snug as a bug in there tonight, hiding from the hail in Dallas.
  • Haha 1
I went and measured again, swung the tape back and forth to find the tightest spot.  The door opening is 7' exactly,  but the door stops at 6' 9" when fully open.  There is a small incline when going into my garage which I suppose could make a difference,  but back to the point,  when I stopped under the door and measured I have a 2" clearance between the shark fin and the door and the radio antenna hits about 3" worth.  I'm pretty confident that with a lift and big tires it won't fit.
When I test drove the AT4, I drove it home, it would not fit
Hm. Must be a problem. My dealer's body shop told me they had 2 new Sierras in for that exact same thing. They were replacing the lettering.
On 5/7/2019 at 10:31 PM, Keta said:
My recent discovery... In the past week, 3 random people have asked me to show them that "special" tailgate on my Denali. I guess the commercial is working.
People actually stop and talk to me in parking lots to show them it.
Anyone notice if you floor the gas pedal, there is like a button at the bottom? Not sure exactly what it does, seems like maybe it immediately causes a downshift for max acceleration.
My 2014 Ram had this, but I don’t think my 2017 Silverado did.
My Cruze has the same step at the end as well. I don't see any relation between this and immediate downshift. I don't feel that much difference when the pedal goes to that stage.
Had the same issue but my truck the passenger side Z71 emblem was crooked angled down towards the front of the truck, driver side was level. I didn't notice it till after about a month as the truck was sitting by itself in my work parking lot and as I was walking up to it I saw it drove me friggin nuts till I was able to fix it. Heated it up with a hair dryer and pulled it off re-applied with 3M tape now its straight. Didn't bother taking it to the dealer and have it sit all day when I could just do it in about 1/2 hr or more.
Found this out after visiting the dunes this week.  While filling up tires, the truck will honk at you when they are up to pressure.  In my case, it was around 40 PSI.  Pretty cool feature.
  • Like 4
  • Thanks 2
I just tried this on my lt TB and it worked.. also noticed the turn signal closest to the tire flashes, doesnt consistently flash so i wonder if it only does it when the truck reads a certain psi.
Sent from my ONEPLUS A6013 using Tapatalk
I've been reading through the manual and I saw the section about the filling your tires (page 370 for those that want to look it up). I kinda skimmed over it because I just assumed I don't have the feature, but mine is an RST so maybe I do.
Quote
This feature provides visual and audible alerts outside the vehicle to help when inflating an underinflated tire to the recommended cold tire pressure. When the low tire pressure warning light comes on:
1. Park the vehicle in a safe, level place.
2. Set the parking brake firmly.
3. Place the vehicle in P (Park).
4. Add air to the tire that is underinflated. The turn signal lamp will flash.
When the recommended pressure is reached, the horn sounds once and the turn signal lamp will stop flashing and briefly turn solid.
Repeat these steps for all underinflated tires that have illuminated the low tire pressure warning light.
Quote
If the tire is overinflated by more than 35 kPa (5 psi), the horn will sound multiple times and the turn signal lamp will continue to flash for several seconds after filling stops. To release and correct the pressure, while the turn signal lamp is still flashing, briefly press the center of the valve stem. When the recommended pressure is reached, the horn sounds once.
If the turn signal lamp does not flash within 15 seconds after  starting to inflate the tire, the tire fill alert has not been activated or is not working.
If the hazard warning flashers are on, the tire fill alert visual feedback will not work properly.
  • Like 4
Hmmmm,adjustable sun visor....????
Wondering what they could have added as more useful convenience .
Sun glass holder ......
Tray in console......
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
