artacus Posted November 15, 2018 Share Posted November 15, 2018 13 hours ago, lawnboy-5247 said: Sounds like I have no need to waste time with clear coat then. Looks Like I should be good to go this weekend besides finding someone with a wall mount spring compressor because the rental ones are a little bit sketchy for me. I'm doing mine myself. Around here it $60-100 for a shop to swap the springs for me. Harbor freight has a tool that appears to be fairly safe. Figured if one is good two is better! Part # 63262. Quote Link to comment Share on other sites More sharing options...
Snowcamo Posted November 15, 2018 Share Posted November 15, 2018 I'm doing mine myself. Around here it $60-100 for a shop to swap the springs for me. Harbor freight has a tool that appears to be fairly safe. Figured if one is good two is better! Part # 63262. Yeah your gonna need two sets. On top of that the clamps will not fit completely around the spring and you'll need an impact unless your fit like Popeye. Please be careful and position that spring perpendicular from your body. Sent from my LG-LS993 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
L86 All Terrain Posted November 15, 2018 Share Posted November 15, 2018 No need to clear coat, unless you are a Z71 Rancho owner. Quote Link to comment Share on other sites More sharing options...
cperk Posted November 18, 2018 Share Posted November 18, 2018 Sounds like I have no need to waste time with clear coat then. Looks Like I should be good to go this weekend besides finding someone with a wall mount spring compressor because the rental ones are a little bit sketchy for me. Took mine to a local shop and they charged me $40 to compress and install new shocks. This was after I got a strut compressor from the auto parts store. It was too small and would either have damaged the spring or killed me if I would have compressed it enough to remove the shock. Best $40 I’ve ever spent. These springs are super stiff. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Centex14 Posted November 18, 2018 Share Posted November 18, 2018 $100 was what I was quoted and it would take a day or two before they got to them. Oreillys compressor for me. Worked fine. 2014 z71 LTZVolant IntakeBorla ExhaustDiabloBilstein 5100Rough Country Level Quote Link to comment Share on other sites More sharing options...
lawnboy-5247 Posted November 20, 2018 Author Share Posted November 20, 2018 (edited) I ended up doing everything myself, I rented 2 sets of compressors and used 3 on the spring. The install took me longer than I was expecting and I was in over my head a little bit but I got everything figured out and the my truck rides much better now as both of my OEM rear shocks were bad with only 31000 miles. I opted to put the fronts in the third notch, I could have done the fourth but I do use my truck to and don't want to be staring at the sky when I haul stuff. I consider the shocks to be money well spent specially since they have a lifetime warranty and ride so much better than stock. Edited November 20, 2018 by lawnboy-5247 Quote Link to comment Share on other sites More sharing options...
2018GMC Posted November 20, 2018 Share Posted November 20, 2018 28 minutes ago, lawnboy-5247 said: I ended up doing everything myself, I rented 2 sets of compressors and used 3 on the spring. The install took me longer than I was expecting and I was in over my head a little bit but I got everything figured out and the my truck rides much better now as both of my OEM rear shocks were bad with only 31000 miles. I opted to put the fronts in the third notch, I could have done the fourth but I do use my truck to and don't want to be staring at the sky when I haul stuff. I consider the shocks to be money well spent specially since they have a lifetime warranty and ride so much better than stock. Nice! Make sure you get an alignment! Quote Link to comment Share on other sites More sharing options...
lawnboy-5247 Posted November 20, 2018 Author Share Posted November 20, 2018 I'm getting new tires tomorrow so it will get done then. Quote Link to comment Share on other sites More sharing options...
Sierra Dan Posted November 20, 2018 Share Posted November 20, 2018 On 11/18/2018 at 8:18 AM, cperk said: Took mine to a local shop and they charged me $40 to compress and install new shocks. This was after I got a strut compressor from the auto parts store. It was too small and would either have damaged the spring or killed me if I would have compressed it enough to remove the shock. Best $40 I’ve ever spent. These springs are super stiff. Sent from my iPhone using Tapatalk Amen! It is worth the $40 to have someone else switch them over. Quote Link to comment Share on other sites More sharing options...
Sierra Dan Posted November 20, 2018 Share Posted November 20, 2018 17 hours ago, lawnboy-5247 said: I ended up doing everything myself, I rented 2 sets of compressors and used 3 on the spring. The install took me longer than I was expecting and I was in over my head a little bit but I got everything figured out and the my truck rides much better now as both of my OEM rear shocks were bad with only 31000 miles. I opted to put the fronts in the third notch, I could have done the fourth but I do use my truck to and don't want to be staring at the sky when I haul stuff. I consider the shocks to be money well spent specially since they have a lifetime warranty and ride so much better than stock. Your statement above is why I started the poll about loving or hating your Factory Rancho's Quote Link to comment Share on other sites More sharing options...
Sierra Dan Posted November 20, 2018 Share Posted November 20, 2018 Quote Link to comment Share on other sites More sharing options...
Yondu Posted November 20, 2018 Share Posted November 20, 2018 Just got my final Bilstein strut in. Hopefully I'll have time this weekend. Wonder if I'll have the lowest mileage used Ranchos - 3 weeks, 672 miles. 1 Quote Link to comment Share on other sites More sharing options...
artacus Posted November 25, 2018 Share Posted November 25, 2018 These coils are no joke. My strut compressors barely fit the springs and really taxed them as well as bent the bolts, not worth the risk. So just took them to my local pepboys, $40 and I'm still alive lol. Quote Link to comment Share on other sites More sharing options...
goeb34 Posted March 2, 2019 Share Posted March 2, 2019 What size tires is everybody running with the 5100s? Keeping my stock 20” Denali rims. Pics? Quote Link to comment Share on other sites More sharing options...
