Ok thanks. Did you finally get your window fully replaced? Any leak issues since? [mention=160416]ShamrockShooter[/mention]
Also- does anyone have a build date as late as mine (11/9/18) that is experiencing this rear window water leak? When I called GM and explained situation and referenced bulletin #18-NA-383.. I was told my truck falls out of the affected date window (10/18).
Yes got window replaced but they damaged a bunch getting it out. The water could also be leaking in the holes that the rear spoiler bolts to the truck. It could Also be a bad seal around the window, both of which would be different than most of the leakers.
Any issues since the FULL WINDOW replacement?
Nope. The new window looked slightly different than the old one so GM must have switched suppliers or part number from the early build
2019 TB LT.  build date 2/19.  Rear window now leaking. Both sides upper corners.
Oh joy.   Can’t wait to have dealers techs greasy little d*ck beaters al over my new truck.   Boils my blood just thinking of it.
Hell I can’t even get an oil change without oil residue on my steering wheel and dirt smudges on my seat.
  • Sad 1
This is the first truck I have heard of built after 10/18 with a window leak. They were all suppose to be fixed after 10/18.
Wish that was the case.   I’ve been keeping an eye on it because of the rain we have been having.  And ,  yes she’s wet.   Not happy to bring this up but is what it is.
Edited by Radchad
May very well just be the spoiler with that late of a build. My window frame was cracked, but the dealer also said there was no seal around the spoiler retainer holes which may have leaked eventually too.
Hopefully it’s just that anyway. Once they started putting the goop on the window, I pretty much decided to trade on the refresh. I’m kinda over it, but it will always bug me a little and I know it’s going to leak again one day.
On 9/22/2019 at 1:34 PM, BluEyeItln said:
Keep something in mind.  I found a leak on my 2015 and it wasn't from the sliding window.  It was actually from the third brake light.  They idiotically use a foam gasket to seal the light when placed into the enclosure of the cab.  I found that the gasket wore out and that was causing water to drip down the headliner over the window and to the back seat.  I pulled their gasket off and replaced it with a better rubber gasket from Home Depot.  This may or may not help some of you, but it's info that I'm hoping will help someone.
Yes, my 2010 and one of my 2013s leaked the same way.   Third brake light seal.  Not a hard fix.  Pull the brake light put some sealant along to top and sides of the seal.
Well damn that sucks. At least your not the first so there should be plenty of info in this thread. If it is the upper rail glass guide under no circumstances should you let them seal it. If they won't put in a new window, just call your insurance and file a glass claim and have Safelite replace it.
30 minutes ago, UGADawgs said:
When posting the 10/18 date from GM, are they saying 10/18/2018 or 10/31/2018?
10/18/2018
So , since mine is built 2/19.  That means no window replacement or what ?  I’m assuming it’s all warranty.   I’m nervous to have anyone hacking my window out.  Wish I could just do it myself
I've been thinking about putting in a power rear window in mine.  The window itself isn't hard, the hooking up of the wiring and button for it, that is another story.
Mine has build date 11/9/2018 and is a leaker. Going to dealership tomorrow- going to push for full window replace.
Edited by Kozzy
17 minutes ago, Kozzy said:
Mine has build date 11/9/2018 and is a leaker. Going to dealership tomorrow.- going to push for full window replace.
Just because you have water inside doesn't necessarily mean it's the rear window leaking. In my case it was the 3rd brake light housing that needed resealed. It is going on 4 months since they resealed mine and still no more leaking.
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 749 Guests (See full list)
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
