A lot of the leaking posts mention urethane sealant on the window frame. Examination of the excess squeezed out on mine which remains leak free for over a year appears to be flexible black silicone rubber.
DSCN0948.JPG.a9f4e37026fbcd5040bb2db571e32e96.JPGDSCN0949.JPG.5a405fe4baf00efaf12823399922e54c.JPG
That sealant is applied at the factory and not part of the “fix” that the dealers are performing for the leak.
3 hours ago, Mogur said:
Is the slider you removed still usable for someone with a concerted effort to put in a truck?  Curious.  Maybe you want to sell it?
If so, can it be made waterproof with more seals,etc, when installing?
I  am interested.
Let me know, msg, PM, whatever.  (I am in SE ID)
YMMV
No sir, it has a plastic frame that is bonded to the glass, it's very thin and cracked in two places (that's the root of the problem).  It's garbage or I would have fixed and re-used.
Well got my truck back. I’m semi-confident in the seal since they specifically mentioned it was coming from the spoiler and they said the seal didn’t cure last time so they used a better sealant than the tsb recommends.
But my problem doesn’t end there. Now they have to replace the headliner since it is dropping in one corner and resting on the slider trim. They also cracked the cardboard of the head liner.
then I come home and find a scratch/slit in my leather seat. Someone must have had something in their back pocket when they moved my truck around.
caller GM today to start a case.
I was a “success” story with my rear window leak issues which I posted in here last April/May. I went in and had the TSB done and they clean my headliner and removed the stains. I picked it up and brought it home. I water tested it immediately and it leaked still. I brought it back and demanded a new rear window. I had already opened a report with GM and was documenting everything. Well the window was replaced by the dealer. When I picked it up I inspected it, no headliner stains, and water tested it when I got home. No leaks!!
Fast forward to May 2020 my wife was like hey I saw stains on your headliner I thought they got them out? I was like oh no not again!!! What do you know it’s raining here heavy today and there’s two different leaks on my rear window. At what point can GM just take this truck back? I’m fed up. It’s a lease FYI..
Edited by Ktapper
Welp not home 45 minutes and it starts raining. Low and behold the leak they fixed is still there. Now it’s in 2 places. And now I have a water spot on the headliner which I never had before. I will be contacting a lemon law attorney tomorrow.
if I go to trade this truck in on something else I would take such a hit. This is ridiculous.
Edited by Andrew David
GM didn’t tell you to kick rocks? They told me “dealers are independently owned but we do hold them to a certain standard so we’ll document this” and that was that.
Since you’ve seen both slider and solid window off the truck, was there a huge difference in the frame and seal?
RadoPhan,
The solid window is just plain glass squished onto the body with a thick bead of urethane, like a windshield.   The slider has a thin plastic frame permanently adhered to the glass (see photos).
Edited by Leevon
RadoPhan,
Thanks for the pics. Makes me feel better now about my solid window
Well it looks like I have a February 2019 build that has a leaking rear window. I have not read through all 140 pages of this thread. Is there any key points to pay attention to with my dealer?
I searched but couldn't find any, but just in case I missed it, is anyone having leaking issues with the solid glass rear windows, or is this isolated to slider rear windows only?
The issue is with the sliding windows only. Anyone with a solid window that’s leaking, I believe is actually the spoiler. There’s no place for the solid one to leak, unless it’s installed incorrectly.
Good to know, thanks. Hopefully the new spoiler bolts are being used now that manufacturing has resumed.
If you are referring to the 2019 models before the slider window frame design was changed then yes it has to do with the window.  But "ALL" Silverados and Sierras of the new body style suffer from the spoiler leakage issue.  That is where my leak is coming from since I have the new style slider window without any cracks in the frame.
So it seems now that the real source of the leak are these spoiler bolts that are not properly sealed with the sealant? So water passes through them and soakes the headliners?
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 458 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
