Don't believe I would use that. I have thought about it, though.
It certainly flows.
Edit: the more I think about it, I don't reckon it would hurt. Kind of an expensive option, but if it works, it works. I would love to see if somebody used it, what the finished product looked like.
Don't know how much is in those, it might take two of those kits to do the whole thing. That's a pretty big gap to fill.
First one I did, I used just a squeeze tube of the Kent sealer. Took the whole tube. And it was a huge pain to squeeze out of there. I started buying them in caulking tubes after that. That's much easier
Someone on here used it that’s why I saved it not sure what post number it was
On 3/7/2021 at 7:28 PM, 2016 Sierra Owner said:
Only 1 slight problem with your pic of where the actual leak was. It may have been there but, I'll bet it was actually somewhere else on the window. When Mine was leaking (yellow arrow) the was about 3-4 inches to the left (leak was on the drivers side) of where you are pointing. I actually lifted up the headliner a bit and saw the water coming in. The window track that you see in your picture however acts as a gutter carrying the water (yellow line) to the left or right till it ends. That is what the arrow on your picture is pointing at. The end of the gutter in other words. Now when I had the TSB done at the dealer the leak actually moved from 6-8 inches from the top corner to the water coming in at the very top right corner. (orange arrow)
Looking at that pic, that plastic channel where you have the yellow line, that's what cracks, and then it leaks.  Usually it's either cracked already in multiple places, or it's getting ready to be.  Usually it leaks just as your arrows show...HOWEVER, sometimes the plastic cracks all the way and you can actually see the crack below where your yellow line is.   And it'll leak right at that spot, too and won't usually run along the top of that ledge and down in the corner.
I HAVE seen water come from where the orange arrow is.   That's just the windshield urethane there.   It's really hard to seal effectively.  When I see one of those, I just tell them to put a glass in it.
Back to the plastic channel:  It is obviously glues to the glass.  Then the urethane bead goes between it and the body.   So when that plastic cracks, water runs down inside the crack and into your truck.   Pretty much the same concept that the Ford trucks are dealing with as well.   Except there's no getting to the top of their glasses to try and seal them.
The sealer basically covers the top edge of that plastic channel, and as long as it stays adhered, it should seal it.
As I've said, I have only had one come back on me...and the TSB says if the sealer doesn't work, then replace the glass.  They're just trying not replace as many as possible.  Can't blame them, it's roughly a 1000 dollar hit every time.   So even if half of them come back, they're saving money, and getting the trucks repaired faster as well.
I suppose your mileage may vary depending on who's doing the repair, as to how it looks afterwards.  I strive to make it so you can't tell I've been there.  I usually can find some little sign that I was there, but most others will not see it.   But that's just me.   Nobody's perfect.
Edited by Pacfanweb
Wish I could have you work on mine...or at a minimum train the guy who ends up doing mine!  Sounds like you are well versed on the repair, thanks for sharing your knowledge and results
It's all I do.  Self-employed, water leak, wind noise, sunroof repairs.  Currently I only go to one GM dealership.  The Ford dealers keep me too busy to do much more, lol
Just got my 21’ z71 LT back from the dealer. Replaced the whole rear window at 350mi from a leak drivers side stating that there was missing  sealant at the top from the factory
I wonder if this sealant is in tight supply and they’re just spreading out the very little supply they do have on hand to get the trucks out the door?
Happy to report that my 21 denali factory rear window did not leak while driving in rain that was a combination of wiper delay and wipers at high speed that wasn't fast enough for 8 hours driving thru TN, VA and IL yesterday at interstate speeds.
Fingers crossed or waiting for the time bomb. Time will tell.
Back in the club again after a year and a half dry. I had water the 2nd day I owned the truck with less than 50 miles on it. 2019 ltz. Window was replaced and lasted till now, about 18 months later.
  • Sad 2
Been a lurker for years.  I joined Gm-Trucks today just to reply to the saga of rear leaks.
Bought my LT in Feb 2019.
Apr 2019 noticed water on top of rear seat during a rainstorm in Tampa FL
May 2019 repaired in Virginia. R&R rear spoiler, new sealant and new bolt seals seemed to fix it.  Moved to Huntsville AL
June 2020 noticed a little drop of water on top of rear seat.  Told myself to get it checked but we're in lockdown for a while
Sept 2020 after summer of stay at home, finally got it to the shop.  Water line on headliner all the way across, 8 inches from the window. Dealer R&R rear window and cleaned headliner.  Looked good as new
Oct 2020 noticed a dollar-sized water stain on driver side rear headliner just above window.  Took it back to dealer.  R&R spoiler again.  They left it in their wash booth for 4 hrs and said no leaks.
Feb 25 2021 Cleaning up the cab when saw a large wet spot in same area as Oct repair.  Called dealer and they said bring it back.  R&R spoiler and said the rubber seal around one bolt was cracked.  Tech had over-torqued on last repair.  Waiting for sealant from GM
Mar 18 2021 after 3 weeks in the shop they reseal and drove it in major rain storms with headliner removed on Mar 17.  Service manager was in back seat and got soaked.  Said it was way worse when driving than when parked.  GM inspector has been requested.
Now I wait...
  • Sad 1
Now I wait...
I read this as... with the headliner removed and someone in the backseat, in the rain, leaking, looking for it, can't find the leak?
Now I wait...
Curious....I know you are still within your bumper to bumper warranty by years....  but are you still within your bumper to bumper on the mileage?
@gemarshThey didn't elaborate on the water leak while driving, but that's my guess too.
Did just get a call saying they're replacing the entire back window this time since it was leaking from the sliding window plastic crack that has been previously talked about on here.
For the spoiler, my guess is that when the tech over-torqued the spoiler bolts, he damaged the frame of the roof as well, and that's why it won't seal correctly now.  Service manager said the spoiler torque specs were a recent notice they received from GM.
@bfontenot9  Thankfully yes...31K
Edited by BamaBen
update
Wow @BamaBen what a saga. I feel your pain in all that. Thanks for sharing it.
Stories like this is why I just leave my slight-leaker alone. It seems like interventions lead to more interventions with this particular issue. 🤦🏻‍♂️
Have been through 3 heavy rain storms (truck has sat out)since the repair and no leaks we will see if it holds up
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
