44 minutes ago, 2016 Sierra Owner said:
The motor stays. The window has a gearbox and cables that attaches to the motor. Separate the gearbox from the motor  and remove the window.
Is there anything you can do to repurpose the switch that used to open the slider?  Or, is that just a dead switch now?
Edited by GN2018
Probably just a dead switch. It's more than likely connected to the BCM and that would require someone to program it to do something else if possible.
Edited by 2016 Sierra Owner
spell
I had the dealership replace the slider with a solid window, but now my interior lights don’t work. Wondering if having that slider components completed some kind of circuit, or if it’s something else unrelated. Anyone else have this issue?
On 4/9/2022 at 8:54 PM, Jrodpic said:
I highly suggest anyone with a rear window leak buy some of the Trim-Lok .25” solid tubing and put it in the top gap of the spoiler. Was a cheap easy fix for me that worked for over a year and a half.
https://www.amazon.com/dp/B00NL4D2T8/ref=cm_sw_r_cp_api_i_JPZ941D56Z6QBW5JNSPD
I have a small leak. No headliner staining. My truck is parked inside most of the time so I don’t really want the dealership tearing my truck apart 4 or 5 times and possibly making it worse. I’m interested in this trim-lok meathod. Do you just put the trim-lok in the gap between the spoiler and window or do you mean the gap around the spoiler on top of the truck. Is any sealant used? Thanks for the help in advance.
Does anyone have a service bulletin number that I can reference to get this fixed on my truck? I just called one dealer and they didn’t act like there was anything available. I’ve got a 2020 Sierra and don’t want to come out of my own pocket to fix this.
https://static.nhtsa.gov/odi/tsbs/2020/MC-10180301-9999.pdf
  • 3 months later...
I am unfortunately here with the rest of you with the same problem on my 2019 Silverado RST.  I will be implementing the TSB fix myself since I'm at 41,000 miles.  Apparently the leak has been there for quite some time and I didn't know.
I called my local dealer, Payne Chevrolet in Springfield, TN and asked them if they had either of the required sealers in stock.  They said no.  I asked what was I supposed to do if I can't get them easily and you don't have them. He said, you would have to order them, and then hung up on me.   Amazing customer service when every truck has the problem, GM won't take responsibility and they won't even help you with parts.
Do you have the rear slider?
Yes.  Why, did I miss something in the 230 pages that I need to know?
Edited by Codeman00
No, I just couldn't tell from your truck description or the picture.  There are questions on whether "some" leaks come from the spoiler holes in the roof, but it appears the bulk of the evidence here is from the rear slider frame itself.  Best of luck with the fix.  The write up on this forum is excellent.
Much appreciated!  I can actually see the cracks on the inside looking up at the window channel from inside the truck....so I'm positive I have the same cracks on top under the spoiler. I plan to tackle this project tomorrow, fill the channel with sealant...and I'll report back.
As one of many that have gone through multiple attempts and methods to “fix” the leak, your best bet is just to replace the slider glass with a solid glass. The first 3 “fixes” lasted anywhere from 2 to 6 months before it started leaking again. On my 4th attempt, I had a solid glass installed. It’s been almost a year and haven’t had any leaks. Saves a lot of headache too!
That is VERY disappointing to hear, but good to know going forward.  I can see the crack and it corresponds to where the water is coming in...so hopefully....hopefully that will take care of it.  Time will tell.  Sorry you had to go back to a solid glass.
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
