It rained all day here. Sometimes really hard rain. I looked it over real careful and it's dry. I hope it won't leak. As for the headliner I think either the windshield or the rear window has to come out to get it out of the truck. At least that was the case on my 03 Duramax. Well not mine as it's an extended cab but if it was a crew cab it would.
Sent from my SM-A505U using Tapatalk
My 2020 TB went to the dealer a few days ago for the leak issue on the rear window - got it back yesterday.
It rained last night through to this morning...checked the rear seats and window....so far no leaks.
My dealer arranged to have an auto glass company remove the window and reinstall it as they determined the original seal was defective.
Well... winter is arriving in North Texas today/tomorrow. Cold, windy, and slow and steady rain. Had to put a new dry towel behind my rear seat to get ready for all the leaking. ? ??‍♂️
  • Sad 1
Steady, all day rain here too.  My window will be getting it's first test since being repaired last week.
Well my second reseal failed so back to the dealer for a 3rd time i go. Love the truck but this is getting old quickly
Sent from my SM-G988W using Tapatalk
On 10/20/2020 at 10:53 AM, Jrodpic said:
https://static.nhtsa.gov/odi/tsbs/2020/MC-10171889-9999.pdf
Looking at the pictures from the service bulletin I am convinced it is caused by water running down the top gap of the spoiler. It is either getting in the holes or cracks on top of the window. I am willing to bet that if a gasket/weather stripping was put in to prevent water from getting in that gap it would fix the problem. Someone with a leak should try to measure the gap and use something like this. That’s one of the first things I am going to do once ours if finally delivered.
1/16”? 1/8”? 1/4”?
https://www.zoro.com/e-james-rubber-cord-neoprene-18-in-dia-10-ft-csneo-18-10/i/G7615781/?recommended=true
Got the truck. Measured the gap. 1/4”. I ordered a couple different rubber cords to try to seal it. Will report back how it fits.
Edited by Jrodpic
I like this idea. Let us know how it goes.
When they did mine last week, they ordered  new nuts for the spoiler. Said they were some kind of updated ones to help the leak issue.
Mine is getting worse quickly. It was barely raining here today, and it was a pretty steady drip. The towel was surprisingly wet .
With over an inch in the forecast, and given it won't fit in the garage, I reluctantly called a dealer today and it's going in tomorrow morning.
More to come.
More to come.
“Barely raining” is usually the worst for some reason.
This is a weird one. I've owned a lot of Jeeps with countless issues through the years.
I'm in IT, and not Engineering, so maybe this is easy for me to say but....
I can't believe they haven't figure this one out on vehicles that cost this much.
My 1978 Pontiac Phoenix even stayed dry in the rain.
All that said, I really do love the vehicle, and hope they can find a resolution.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 500 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
