8 minutes ago, rosepaule said:
Yup.  I got it with the help of Travis Lambert. I had to go hulk smash on the center console, that thing that really clipped in there
Lol. That little trim piece under the dash apparently holds the entire truck together. Somebody at GM decided it needed to be CLIPPED IN.
Thats the only “difficult” part of the install.
  • Haha 1
On 6/13/2019 at 9:41 PM, Jessica Lambert said:
I’m sorry, but in order to maintain our competitive advantage we can’t share the exact details of the changes. Please understand that in spite of extensive testing, undetected issues can exist. The problem with our device went undetected during testing because the test trucks were driven daily. Also, since the body control module is what was using the power, we didn’t see this when we checked the draw on our device.
It is rare that a manufacturer offers unsolicited replacements upon discovering an issue. We hope that the way we handled the situation demonstrates our level of commitment to our customers. If you would like to discuss further please contact us at [email protected].
Look/sounds pretty cool, but $90.00?  No thanks.  Not at that price.
  • 4 months later...
I installed my ASE this weekend.  It was a snap with the right plastic trim tools.  Took me about 20 mins.  I'm loving not having to remember to hit that switch any more.
Installed mine a few day's ago works perfectly and if I find the need to use the stop/start all I have to do is push the switch to turn it on.
this is the system GM shoulda used from the getgo
Completely agree that the default for auto-start-stop should be "OFF", but then CAFE wouldn't pass the increasingly stringent EPA MPG requirements, or even better, the liberal-minded EPA would apply some type of "facilitating payment"...
I just realized I don't have auto-start-stop in my Mexican version. All the trucks at the ranch have auto-start-stop though.
can we get a pic of your center portion of the dash below the radio and above the console
I do have that button if you're wondering but it's never done anything. No light either.
Ah, I take back what I said.. the dealership said it is broken, I am supposed to have it. LOL.
My truck always re-starts after about 30 seconds every time.  I maintain constant pressure on the brake pedal but it always re-starts before I release the brake.  All of which makes me wonder how much good it's doing in terms of fuel savings, environmental impact, etc.
There is a long list of things that can make autostart not function, or allow it to restart before releasing the brake.
Auto Stops may not occur and/or Auto Starts may occur because:
. The climate control settings require the engine to be running to cool or heat the vehicle interior.
. The vehicle battery charge is low.
. The vehicle battery has recently been disconnected.
. Minimum vehicle speed has not been reached since the last Auto Stop.
. The accelerator pedal is pressed.
. The engine or transmission is not at the required operating temperature.
. The outside temperature is not in the required operating range.
. The vehicle is in any gear other than D (Drive).
. Tow/Haul Mode or other driver modes have been selected.
. The vehicle is on a steep hill or grade.
. The driver door has been opened or the driver seat belt has been unbuckled.
. The hood has been opened.
. The Auto Stop has reached the maximum allowed time.
Auto Stop Disable Switch
If equipped, the automatic engine Stop/Start feature can be disabled and enabled by pressing the switch.
Auto Stop is enabled each time you start the vehicle.
When light is illuminated, the system is enabled.
its been 6+ months since my Auto-stop has worked. I know one day it will start working again (oil change at dealer, or OTA update, or something will happen) but I’m loving it so far.
I still have not figured out what the dealer did to stop it. Truck got a engine light after a car wash. something related to the brake control module , so I took it in and the dealer said they “re-flashed” the module to clear the light. Never had an Auto-stop event again after that.
I've had my 2020 Silverado for about 14 months. I thought I would like the auto stop feature at first and it did great in my hometown. Not much traffic at all here.
However, when I went to visit family in the Houston, TX area I did not like it at all.
Stop and go traffic along with bumper to bumper stop and go was really bad. I got to thinking, what if the truck wouldn't start one of these times? I turned it off and everything was normal.
I never considered putting a device on to turn it off. I just automatically press the button when I start the truck. Easy peasy.
I love my truck with the 2.7T 4 banger.
Good luck!
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
