Looks like they have a down pipe with high flow cat coming out soon. Curious how this intake performs. Pics and videos please.
When is this engine going to be available in the Tahoe/Suburban platform? Or will it ever?
For those who have had the 2.7 for the past several years, how’s it holding up? Better mpg?
As well, does it come with a g80 locker, was thinking 4x2 crew cab but my only concern is traction in snow. Not for off-roading.  I know tires and weight make a difference. Thanks
As for the mpg, I have 5000 on mine and am averaging 23.1.
As for traction, it has plenty of power to spin the rear easily. Much more so than the 16 silverado I had with the 4.3.
Almost 4,000 miles on mine  (4 x4) and  last tank 26 mpg on highway (driving 55)   22-23 around town
They've only been around for 2 model years so I don't think you'll find many people that have put 30-40k miles on them. I got mine a month before this COVID bullshit so I'm getting tremendous mileage. 1-2 weeks to a gallon probably. [emoji23]
Get the diesel you won’t regret it and it comes standard with the 10 speed.
And it's only  about $5,000 more
$3800 it’s a bargain. Includes the 10 speed.
Edited by ILSilverado
I am thinking of trading in my 2015 1500 Silverado LT 4.3  for  the  2.7, but after researching the mpg I am hesitant, my 4.3  constantly gets 22 to 23 mpg ( rural driving )  and have had up to 25 mpg driving 75 mph in the mountains of Colorado. So the gain in mpg of one truck over the other isn't much.
Wondering what other's opinions might be on my thinking, a new 2019 or 2020 with 2.7 would be close to 12,000 and my trade in. Factory discounts aren't as much as back in the winter on this set up,
I think you are missing the additional all - star discount you get with the 2.7, again at lest $5k more.  When I bought mine, (11/19) I got about 30% off the MSRP  as they were  almost giving the 2.7 away.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
