4 hours ago, AMPRG said:
Take it back to the dealer for software update.
Did that. Nothing different on my end. Did it work for you?
so o have a 2019 silverado 1500 LT and am having this same issue I have had the issue since day 1 aswell. Dealer replaced the camera still have the issue. Dealer advised me GM is working on a fix and to contact them to ensure even if i am out of warrenty it would be fixed. GM has given me the run around no answer nothing assuring me they will fix it when one becomes avilable to the point my issue was escalated after speaking several times to the senior advisor 2 days ago I recive a email stateing they cant reach me at my contact number proived... the same number i have spoken to them on multiple times so i called and left a voicemail with my number again haven't heard a word. From the start GM has given me the run around i owned a 2015 camaro. And now currently own a 2019 silverado and a 2018 traverse and im done with GM after this im so pissed they have been giving me the run around for over a month and no resolution they actually deny and claim there are no bullito  on the issue even when i give them the bulliton id the dealer gave me they actually told me he isn't supposed to have given me that. So GM has lost a customer after this oh and now today my Brakes say service brake system. 16,500 miles on my truck and nothing but problems **** you GM I'm hiring a attorney and filing for a lemon law
good luck on the lemon law i went to see an attorney he said would take 2 years to settle the case.. told him forget it i would trade the truck in before that.....i am have the same issue with the camera, but i have a intermittent   miss fire that comes and goes had truck 8 months only 4500 miles on it. its been at the dealer for 2 weeks now cause they need it to happen while they have it so god only knows when ill get it back..  GM is no help ..
Just got a 2019 RST and having the issue.  Strange thing is it didn't happen when I test drove it.  Kinda bizzare.
Hey guys, wanted to share that mine 2019 LT with 8in screen has a poor grainy camera, even flickers like a 80s tv. I am considering looking into the wiring to see if it can be tapped into using an aftermarket camera.
Having the same problem with my truck too. Sucks to have purchased a brand new truck that comes with issues. Also sucks to have GM say that because you didn't spend more on a higher package, your camera/screen is gonna suck, sorry, not sorry. However, besides that, I do love the truck.
Got the service camera system message last week.
Horrible picture, grainy at all times, and it flickers with the touch of the brake or any other power draw.
Still "working" though.
Same result.  Truck to dealer w/ screen going out in reverse and lines while braking.  Radio replaced but did not resolve.  Dealer contacted GM, stated they recognize the issue and do not currently have a fix.  Just piling on my experience.
Edited by 2019SilvRST
I have a 2018 Sierra Duramax with SLT package and I get blue screen with “service rear camera” on screen. Happens often and always when truck is cold first thing in the morning. I’ll be call GM and NHTSA
OK I have a 2019 Chevy Z71 RST model I purchased and took home December 27th 2019 with 176 miles on the truck.  At night time sure enough, I pet the truck in revers to back in my driveway and I have this HORRIBLE grainey / Pixelated display and on one occasion the camera cut out and went back to the normal display screen.  I took it to the dealer on January 27th 2020 with 865 miles on the truck. They had the truck for three days to inform me that they could not reproduce the problem and that they compared it to other similar vehicles and it is operating as normal.  They also told me that I DO NOT HAVE THE HD Camera. (I though the RST had an HD Camera) They also told me there was no FACTORY HD Camera I could add to my truck.  Because the rear camera's picture quality is so BAD it is useless and when I went to just turn off the screen so I couls see out the mirrors with out the interfearance of the bright screen light, it appears that Chevy neglected to provide the ability to turn OFF the screen...... It's hard to believe that Chevy does not have access to the same camera technologey as other vehicle manaufactures or a too cheap to provide all of thier vehicles with a quality camera in light and dark conditions, especialy in a $46,000 truck. I want this issue resolved!
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
