I actually read that. I want to keep the rake because I actually like it. Thanks for the heads up though. Your picture convinced me to make the purchase. So it’s all your fault. Lol
Here’s mine. LT TB with motofab 1.5”. Pics are a little deceiving. There is still just a hair of rake.
Bringing my truck in tomorrow to have some warranty work done. I asked about them installing my level kit. Will see tomorrow how much they wanna charge me
On 5/29/2019 at 4:01 PM, Thejet07 said:
Anybody have a 1.5” or 2” level with 1” rear block? I’m looking to put level up front but want to keep rake. I wonder if a 1” block is too much on a 1.5” level?
52 minutes ago, Stormtrouper said:
CTB, 1.5 motofab, 3" rear block, bushwacker oe style flares, 1" rake on level ground, 2" wheel spacers, etc...
What kind of wheel spacers did you use and did it effect your ride/drive quality?
straight motofab 1.5 level on stock everything.it does actually have about 3/4 inch rake yet
this was bought for the wife as her grocery getter
gator sfx cover
motofab 1.5 level
and other  goodies
Edited by newLT290
added info
Custom made to order billet from Wheel specialties in Tampa $65 each shipped. So far so good. Asked for BORA, installer recommended these.
Came with nuts also!!! Total ride stiffer than stock but steady in curves at speed. Pulled my travel trailer over the weekend and can't tell it's back there. Have pulled my loaded tool trailer also, no issues.
I really like your setup, thinking about doing the same. Any rubbing? Any issues?
Thank you!
No rubbing up front, slight rubbing on the back.
I trimmed half of the mud flap and right now it slightly touches the fender liner when reversing.
I did not trim the liner.
Caliper clearance is great, not even close.
There is probably 1&1/2- 2 inches of space between caliper and the spoke.
1af96015e0c58add2b7596822dde5170.jpg0a05995d6b08955866cba2cc9dedeb1e.jpg4fdcd9ef19d2f8f2852181ff26f3af7f.jpg
Sorry for the bad pics but this is full turn after trimming
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.
    • Triumph makes me think of cars not bikes. Especially with model names like the TR7, that was a Triumph car model too. Peak TR for me was the TR250. You could retain the post-war roadster looks, with an optional surrey hard top, but with an inline 6 engine instead of the TR4's anemic 4-cylinder, but still have a 4 speed, optional overdrive.   I know almost nothing about Triumph bikes, except that they exist. Good looking bikes though.   I don't know if I could just have one vehicle. The Silverado does it all except for fitting anywhere. But it leaves a void in real driving enjoyment, unless driving an extremely large sofa is your thing.   What did I do to my 'other' (muslce car - which one!?) vehicle lately. I took my '23 SS for a drive. It's only got 1600 miles. I keep reminding myself I shouldn't be so precious about this car. It likes to be driven. Needs to be driven. Life is short and if I don't enjoy it, someone else will. The other half calls it "the garage ornament".
    • Hey everyone, Thought we’d share our 40" SLIM Light Bar setup for the 2022+ Chevrolet Silverado 1500 for anyone looking at behind-the-grille lighting options.   The 40" bar sits behind the lower factory grille, so it stays pretty well hidden when it’s off. The mounting position is also adjustable, which helps with getting the bar positioned properly depending on the grille.   A few details on the setup:   40" SLIM LED light bar Fits 2022–2026 Silverado 1500 Spot + flood beam pattern White, amber, or white with amber DRL backglow Adjustable mounting position No cutting or drilling required Doesn't interfere with the active grille shutters Vehicle-specific mounting brackets       It’s a straightforward option for anyone who wants the coverage of a 40" bar but prefers to keep the front of the truck relatively stock-looking. Curious what the Silverado owners here prefer — hidden behind-the-grille lighting or an exposed bumper-mounted setup?
    • Yes. Absolutely. That doesn't mean I don't like and enjoy a variety of machines. I went for a time with no other vehicle than a 1976 Triumph TR7-V Tiger. Loved that bike and rode it 365 in any and all weather. I did not feel deprived of anything.
