On 4/8/2020 at 3:47 PM, Vasa1 said:
Hey there. Any issues with rubbing with that setup? I want to do the exact thing.   I see ur in a parkade. No clearance issues? What type of leveling kit did u use?
Edited by Vasa1
On 4/16/2020 at 1:08 AM, ausomecasey said:
1” level with non-LT 275/60r20 ridge grappler
Edit: originally specified wrong tire size, sorry!
Where did you find a 1" level? I have a 2020 custom 4x4 now and it only has a 1.4" rake so I'm scared of the pro comp 1.5" level as I don't want to reverse rake.
Motofab makes a 1” lower strut spacer.
Mine is the Motofab 1” level. https://www.amazon.com/dp/B017WN0G1U/ref=cm_sw_r_cp_api_i_zxHMEbMCW9R90
Supreme Suspensions also makes a 1” level,  but you have to call them. See my screenshot for their number...Only thing about supreme suspensions...their 1” is either silver or black, and they weren’t sure which color they had in stock...
On 4/16/2020 at 11:01 PM, ausomecasey said:
Thanks! Here you go...let me know if you want any more...compared to LT version, you can see the tread depth is a little less, and the side wall is a little less aggressive. But they are still a nice upgrade from stock tires. They basically ride like the stock tires, and they only weigh a few pounds more than the stock tires. Only minor negative thing when compared stock tires...these tires have a little hum. My wife doesn’t notice it, but I do. Not bad though, just more than stock. Overall very pleased with them...
Thanks for the pic and the clarification. I didn’t think they made that size but was getting very excited. Even though it’s the same size as the factory Goodyear’s they look a lot more beefy.
Haha, yea, I would love a ridge grappler non-LT version of the 285/60r20 or 275/65r20. They make the Terra grappler in a non-LT 275/65r20...if I ever add the trailboss lift, I might try those Terra grapplers just to have a little larger tire since it would be lifted more...
Edited by ausomecasey
On 4/8/2020 at 8:07 PM, brianc636 said:
I’ve been thinking about this size of tire but wasn’t sure how bad it would rub with my 1.5” level. Got pictures of your mud flap trimming?
Tire and wheel Combo look great on that truck.
Here's mine fella's. 20' AT4 w/duramax.
2 in RC level kit. Falken AT- 295/60. Fuel Rebel 20" wheel. Minor rub on the felt liner at full lock. Don't notice it enough to even think about switching!! Haha. Stance and ride is great imo. RC level kit didnt mess with factory AT4 ride either.
  • Like 4
First photo (side view truck has the 2 inch Readylift) since been removed cause the boot contacted the bottom part of the strut. Added Rough country 2 inch leveling struts and the Readylift was removed. Plenty of cv axle clearance now  . 20x9.5 on 285/60/r20. It’s my vets truck. He said no rubbing and rides a lot better than factory. D2A65615-3C89-4782-86F7-4A8D688F9E79.thumb.jpeg.bd8df8bc931a278ae34cbc782ea8dd1c.jpeg
Looks great! How’s the angle of the upper ball joint without the RL upper arm? I’m was just about to get the RL kit when I started reading the 4 wheel high issue. We use that all the time in MI.
On 4/16/2020 at 1:24 PM, woychc said:
1.5” motofab level kit
Really like the look of your truck. My dealer installed a 2” rough country and my X31 is now sitting nose high.. Did you have any issues with the Motofab 1.5 rubbing like others have talked about? I’m even thinking about going to a 1”.
Edited by Matt4704
No issues yet, I only installed it a few days ago. Lots of room, won’t rub unless you do some serious off-roading.
I added air bags & an on-board compressor, it brought the rear up 3/4” or so since these pics. Little bit of rake, I like the look.
How is the RC level on the already lifted truck? How’s the upper ball joint without the new UCA’s? Can’t decide between that or the RL with UCAs
Angles are good on it! I don’t have any photos to show though.
Yeah those lower strut spacers are not worth it with the new trucks. Why take a chance. That's why Rough county got rid of them. Up date on the Rough county leveling struts. They did seem to settle some after a couple of weeks . Was a full 2 inch lift.  Maybe dropped a 1/4 inch to 3/8. So a 1.625  to 1.75 off lift. Love they way the ride. Have about 3500 miles with them now.
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 1,589 Guests (See full list)
