How does it ride?
Wow looks great! So you are basically at trail boss height with the 2” level kit and can fit 35s on aftermarket offset wheels
Fuel Shok Bronze 18x9 +1offset
with the Stock Duratrac tires - no additional lift or level
Discount Tire had ordered me a set of black lug nuts, but they were delayed so the chrome lug nuts are temporary.
20x10 fuel assault -19 offset, centering rings, no spacers, 295/65 ridge grapplers, 6" fabtech lift, no rubbing
On 3/5/2020 at 7:41 AM, KillerOfMillers said:
18x9 +1 Fuel Shok
295-70-18 Falken Wildpeak AT3
I like this set up and stance. Looks good. What suspension setup are you on? any rubbing and/or cutting involved?
Had some rubbing, a little minor trimming on mud flaps took care of it.  The front is lifted 1.5" over stock using FabTech DirtLogic coilovers, the rear is stock height also using DirtLogic shocks.  Kit also included Fabtech upper control arms.
On 7/15/2019 at 12:09 AM, GJM32387 said:
Fuel Rebel 20x10 -18 Offset
No spacers
Nitto Ridge Grappler 295/55/20
Factory Trailboss Suspension
Slight Rub on mudflap on full lock.
For stock, it sure sits level !
On 3/11/2020 at 3:41 PM, Troger said:
Nice looking truck.  Were the side badge/vents easy to replace?  I'm looking at changing mine to those.
It's a W/T. That's how it came.
On 9/20/2019 at 6:21 PM, foxcoupefan said:
17" Method MR 312s. 35/12.5/17 KO2s, Baja Kits Chase Kit Suspension (Front King coilovers w/remote reservoirs, boxed upper control arms, rear Kings w/remotes, 1" lift rear) . No rubbing.
Love the setup - just ordered the same kit for my 2019 Sierra SLT.  What offset are you running on the Methods, what height are you running on the coils, and did you get the 1" block to bring it back to level (if so - where did you order the block)?
Sorry for all the questions, but I should be installing in the next couple of weeks.
285 45 22s on oem replicas. I went the budget route to get me into some 22s. Now im wanting to upgrade for a little more sidewall to either 275 50 or 305 45s. What y'all think?
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
