1 minute ago, Linh Nguyen said:
Correct, 6” Fabtech lift and thanks!
I’ve got a BDS 2” going on my 20 AT4 this week. It’ll net me 4” total. Also have 20x10 -18’s and 35/12.5’s to install. I know I’ll have to trim some but that’s part of the fun!
Stock 22's currently but I dig them. Comfortable, no road noise, and can't go wrong with black on black. Maybe down the line might add a lift and switch up wheels especially after seeing everyone's setups !!!
Got my new wheels mounted today. 20" TB replicas in titanium grey from Florida Speed Shop. Highly recommend them for wheels. Transaction was easy and shipping was fast. I love the way they turned out on my truck. Still running stock tires until they're due to be replaced and then I may go with something more aggressive.
That really looks good!
Thanks! Every truck I've ever had has been red with black wheels so I decided to try something a little different this time. The titanium grey has a lot of personality in the sunlight. I'm glad I went this direction.
Went and got me a Rocky Ridge Sierra and traded my AT4. 6” Rocky Ridge Lift, 35x12.5x20 tires and 20x9 wheels. Love it so far and I think I can stuff 37’s once I wear these out.
2020 Sierra 1500 SLT. Stock suspension/no lift.
My first foray into the world of GMC trucks with 20 inch wheels and tires.
I just finished browsing through all 34 pages of this forum thread...wow, what a great place for wheel and tire advice!
My truck came with Bridgestone Alenza 275/60/R20. Not a bad looking tire, but I think I'd like something a wee bit taller and all terrain. What options do I have to keep the stock wheels but get a taller tire and not have to cut/modify the wheel well housing? In a couple of the forum posts I thought I saw someone with stock suspension saying they had installed 285/60/20 or 275/65/20, but I failed to notice if they had a AT4 or a SLT like mine.
If anyone has pics of a stock SLT setup w different tires, please share!
Thanks in advance for your help!
Daryl
22x12 -45 Fuel Mavericks with 325/50R22 Ridge Grapplers.
This size tire is slightly louder than the smaller 35x12.5 Ridge Grapplers I had before but still very quiet on pavement.
No rubbing forward or reverse after some minor plastic trimming. I had previously removed the mud flap bracket and tied back the wheel well liners.
Edited by BlackLS
Nice truck man! Front end looks really aggressive. Can you send me a link to the silver piece you have on the lower bumper? I’m digging that!
Started out with a leveling kit but after a few months I went with 6in RC lift with skid plate strut spacers and N3 shocks.  Air dam removal. Kept the Nitto G2 295/60 r20 since I already had them when I did the leveling kit.  May upgrade to 35x12 later but with the 34s there was no rubbing or cutting needed and the acceleration is good.  Fuel Rebel 20x10 are the rims.  Side steps are also RC.  Rides smooth as factory. Also added GM cold air intake and Black Widow exhaust.
Edited by Satinsteelmetallica
I’ve also had a leveling kit for a month or two and already know I want the lift instead too, haha.
Nice truck.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
