On 5/28/2021 at 7:20 PM, f0urtw3nty said:
advan rgd2 17x8.5 -10
35x12.50x17 km3
trail boss w/kings
Got any full body pictures of your truck?
On 4/19/2021 at 9:06 AM, ms6040 said:
2021 RST Z71. 265/60/20 Ridge Grapplers. Stock wheels. Bilstein 5100's all the way around. Front set in groove #5, 2" setting.
Stock RST wheels with the more aggressive tires look great!
2 hours ago, Muddturtle1231 said:
How do you like the Go Rhino's?
I really like them! I would love to have AMP Research steps, but I didn't want to pay that much.  They are very solid feeling and the install was very easy.  I got the bed lined version and really like them
18" Black Rhino Mozambique wheels/ Falken Wild Peak AT3 275-65-18 tires, 2" ReadyLift levelling kit.  Drives great, still gets 25+ combined mpg, and it dropped 11lbs per wheel/ tire compared to the stock 22's.  Overall diameter is down slightly compared to stock, but exactly the same as the AT4 18" setup.
Edited by Dmax3
Details
With the 2" ready lift, did you check your before and after measurements? I've read many other said they really only got about 1.5" out of the spacers.
Wow, that looks awesome, makes me want 35's and that bumper on mine.
On 2/11/2021 at 9:22 AM, Wakinvol said:
Going against how I have been for MANY years I made a subtle swap this time...went from the stock 275/65-18's on my TrailBoss to a 275/70-18 Ridge Grappler. I wanted to keep my power, good ride, and performance. I have scowered the board looking for pics of another and couldn't find any. Overall I am pleased. I had 295/70-18's on my previous Titan XD and I know they would have fit here, but I didn't want a stuffed look. Also didn't want to level it and have to change the UCA's so here it is:
 I've been looking for this exact tire set up with stock / nearly stock suspension set up.  Thanks!
Edited by Dmax3
On 1/6/2022 at 6:15 PM, paxamus said:
Cognito 3" lift with Fox Coilovers.
35x11.5x20 Toyo Open Country ATIII on stock rims- minor trimming and mudflap delete with McGaughy's Mudflap delete
2021 Z71 (Debadged except for the DURAMAX) LTZ
3.0 L Duramax
Auto Stop Eliminator
Diamondback HD tonneau
Go Rhino Running boards
Complete LasFit LED light conversion
Did you have to use spacers to retain your factory wheels? Their website mentions  5.75 backspacing
On 1/19/2022 at 4:34 PM, PeaceKeepr said:
Very nice set up. Any rubbing? Trimming? Details on the bumper/skid plate?
Sorry, just saw this.
No rubbing. I did do a mud flap delete kit from Mcgaughys in the front. The bumper is ADD Offroad Stealthfighter bumper.
2020 RST Z71
20X9 +1 Fuel Rage black&milled wrapped in AE07D955-6F6A-4607-A966-AEB26568AFEF.thumb.jpeg.abdddf06fdc59a0d43d980b6bd83d6d3.jpeg33”x12.50” Mickey Thompson Baja Boss A/T’s. I have a 3” Superlift suspension lift and the Borla exhaust with the black chrome quad tips.
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 965 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
