lonewanderer812 Posted May 3, 2022 Posted May 3, 2022 17x8.5 +0 Icon Compression with Falken Wildpeak at3w 285/70/17. Suspension is Bilstein 5100s with front set at the second highest mark (got a little under 2" with the diesel) and a 1" block in the rear. 5
Trailboss_6Duece Posted May 6, 2022 Posted May 6, 2022 On 12/19/2019 at 6:15 PM, Cmillerjr said: Stock wheels with 295/70 R18 Cooper Discover AT3/XLT. What’s your suspension set up?
Cmillerjr Posted May 6, 2022 Posted May 6, 2022 12 minutes ago, Trailboss_6Duece said: What’s your suspension set up? I don’t have the truck anymore but, it was a just a Rough Country leveling kit.
Bhains187 Posted May 9, 2022 Posted May 9, 2022 On 3/28/2022 at 10:28 PM, Mattuz93 said: 3.5” Rough Country lift 295/65/20 ridge grapplers any other pics of this setup? did the lift come with new ucas?
pepe48134 Posted May 10, 2022 Posted May 10, 2022 Stock Wheels 275/65R20 Nitto Recon Graplers (Metric Non-LT version only 47.5 lbs) Bilstein 5100's @ 2 inches, Stock rear height. rear is 1/4 in higher that front but looks nose high to me. I going to install 1.2" blocks from Pre 2019 trucks to level it back out to the eye. 1
dieselfan1 Posted May 12, 2022 Posted May 12, 2022 2022 LTD High Country Fuel Maverick D536 chrome 22x10 , +10 offset Michelin Defender LTX MS 305 45 R22 Stock suspension. Tiny rub in reverse full lock easily fixed.
Surcee Posted May 16, 2022 Posted May 16, 2022 Certainly appreciate everyone posting information here with pictures. Helped a lot. I finally got my lift and wheels on this weekend. 2021 Silverado Custom. Added a 4" rough country lift front and back. Fuel hostage D625 rims are 20x9 +1. Terra Grappler tires are 295/65 R20. I don't feel there is a difference between stock and modified ride. Rides and handles great. Required some trimming to the fender liners but not bad. 2
z28tranz Posted May 19, 2022 Posted May 19, 2022 On 1/10/2022 at 2:24 PM, tomthetrex said: 2021 Z71 Duramax RST Fuel 18x9 Couplers Toyo Open Country ATIII 35x12.5r18 IVD Stage 2 w. Element Hard Parts UCA. How much lift did this give you? I want to do the same setup and I want to be sure it will give (AT4) at least 1.5" of lift.
SilverMak Posted May 30, 2022 Posted May 30, 2022 On 5/10/2022 at 6:11 PM, pepe48134 said: Stock Wheels 275/65R20 Nitto Recon Graplers (Metric Non-LT version only 47.5 lbs) Bilstein 5100's @ 2 inches, Stock rear height. rear is 1/4 in higher that front but looks nose high to me. I going to install 1.2" blocks from Pre 2019 trucks to level it back out to the eye. I’m thinking about something similar and want to hopefully improve the ride. I was unaware on a non-LT of that size tire. Do you think a little extra sidewall improves your ride? How do you like the ride compared to stock? Your truck looks great.
SilverMak Posted May 30, 2022 Posted May 30, 2022 On 5/10/2022 at 6:11 PM, pepe48134 said: Stock Wheels 275/65R20 Nitto Recon Graplers (Metric Non-LT version only 47.5 lbs) Bilstein 5100's @ 2 inches, Stock rear height. rear is 1/4 in higher that front but looks nose high to me. I going to install 1.2" blocks from Pre 2019 trucks to level it back out to the eye. Also, did the larger tire have a big impact on gas mileage? TIA
Bikerjon Posted May 31, 2022 Posted May 31, 2022 Stock wheels, 275/65/R20 Goodyear Dura Tracs. Factory 2" lift (Trail Boss).
jashaw Posted May 31, 2022 Posted May 31, 2022 XF offroad XF222 wheels -12mm offset Cooper Discoverer Rugged Trek 275/60R20 (factory size) Removed lower wheel liner bracket, and pinned wheel liner back in empty space that was filled by the bracket with self tapping screw. No rubbing at full turn in either direction. 3/8" spacer to clear calipers. Bilstein 5100 all around (Front on setting #5 2") 1" rear blocks 1
pepe48134 Posted June 10, 2022 Posted June 10, 2022 On 5/30/2022 at 6:55 PM, SilverMak said: I’m thinking about something similar and want to hopefully improve the ride. I was unaware on a non-LT of that size tire. Do you think a little extra sidewall improves your ride? How do you like the ride compared to stock? Your truck looks great. Sorry for the delay, Hard to tell if the ride is much different from the Tires or the Shocks. No Noticeable difference in MPG. I think the tire weight of the Non-LT tires help (11lbs per tire lighter then the LT's, unsprung mass is bad for MPG). Nitto is the only MGF the has a Non-LT tires in this size and the make both the standard and the LT in the same size so you have to be very specific on what you order. I got them from Discount Tire.
