Got my 2020 2500HD Denali on Friday...
Level kit and Amp retracts running boards
  • Like 4
2 1/2  weeks old. 700 miles.Great truck.
IMG_4810.thumb.JPG.dee6c233f5b5ccfb508bd8817fa6225a.JPGIMG_4808.thumb.JPG.c1d6f61b943b26a22f2aa02b259cc171.JPG
  • Like 9
Looks awesome..How are you liking the new 6.6?
it seems considerably stronger than the 6.0 that was in my 18 . i tow a 24' enclosed car hauler that weighs about 9000 pounds loaded, so its not real heavy. i'am pleased with it so far but i only have about 100 miles on it with the trailer. i haven't payed close attention to the mileage yet but it is better than the 6.0 was. the 3:73 gears are ok but i think the 4:10's would bring the motor alive but with a 6 sp. would probably hurt the mileage too much for some guys .  so far the motor is super smooth and i'am definitely pleased with it.
  the next step is to get the tpms in the trailer wheels and the 2 accessory cameras on and in the trailer.
Good to hear.  I also need to get the sensors in the trailer tires.  Are you getting the accessory camera’s from GM or somewhere else?  I’d like to get a couple as well.
On a side note, if anyone is taking aftermarket wheels with sensors from their previous truck, the sensors have changed.  The new style are $34.00 a piece from GM.
i'am going to get the GM accessory cameras, don't know if it matters  but i feel better with GM parts that were originally designed to work with the system they designed. i'am planning on ordering them from the link posted in another thread on this site. they seem to have the best price.
On 8/31/2019 at 6:19 PM, BB&Chiveon said:
what level kit?
I dont know... the delaer gave me the original torsion keys and added 1" blocks in the rear.   It drives nice.  Call Dennis Dillion accessory shop and ask for paul.. he can tell you what kit they use.
I had my dealer sell them to me for $50 since that was the price when ordering the truck, they wanted $150 at the dealer.  He had to order them so all I have right now is a We Owe
30 minutes ago, powerhaulic said:
Fresh wax, vent visors, and exhaust tip done.
Also installed the tonneau after the pic was taken
nice looking truck !!  where did you get the vent visors? i haven't seen any 2020's in the aftermarket and i checked with my dealer 2 weeks back and he said they werent available yet?
Dealer had them in stock, Got $1000 in accessories thru GM business choice program.
Should have the rest of them this week.
Putco rear light blade, couple ball mounts, console organizer
  • CRApex changed the title to 2020 HD picture Thread
On 8/30/2019 at 10:28 AM, mookdoc6 said:
Please STOP POSTING THE HD'S...........I WANT ONE!
I agree 100%.  Some people dream of exotic cars if they win the lottery...my dream vehicle is on this page!
New to the forum, so I'll start by saying hello and I look forward to learning all I can about the 2020 trucks.  I picked up a 3500hd ltz Duramax on August 8th and already have 3000 miles on it.  I've done about 1000 miles of towing with it already and it is a beast.  I went from a 2016 3500hd with the 6.0 and I'm just amazed how much less this truck works pulling the same load.  If anyone has any questions feel free to ask away since I already have about month behind the wheel.
  • Like 6
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
