My 2021.  RC Leveling kit on it with 35 x12.50 x 20 Firestone Tires.
Truck0221-5.thumb.jpg.001d5e95797547cfdca6679ed6d3eb4b.jpgTruck0221.thumb.jpg.ced0351a2b6b4145731add7cc67bc324.jpg
Edited by RickW.
My 2021 Sierra Denali 3500 long box duramax arrived on Wednesday, happy it came in three weeks early. Loving it so far, these new trucks are so much bigger!!!
Traded in my 2015 early run Silverado 3500 Duramax LT, paid 48k for it in 2014 and they gave me 45k in trade plus the additional tax credit. Sad to see it go but have been mad about lacking the newer style mirrors once they updated them a few months after purchase in 2014.
Here is the new one and the trade. Added Fuel Blitz 20x9 +20 offset in black with Nitto Ridge Grappler 295/65/20 tires, stock height. Have a Bakflip tonneau on order, tint schedule next week, and window vents to install. Sweet ride so far!!!
Just picked this 2020 Sierra 2500hd AT4 used and traded my 2005 Nissan Armada.  Wow, this is different!  Riding on Nitto Ridge Grapplers 37x13.5x20 with a small lift kit.  Some rubbing which I will have to address.  First time Diesel truck owner and loving it.
Edited by G Fouts
spelling
Just picked this 2020 Sierra 2500hd AT4 used and traded my 2005 Nissan Armada.  Wow, this is different!  Riding on Nitto Ridge Grapplers 37x13.5x20 with a small left kit.  Some rubbing which I will have to address.  First time Diesel truck owner and loving it.
Looks awesome!!!
Looks great!  What/where/how much rubbing are you experiencing with those 13.5's?
Looks great. What did your use for the color matching on the front end?
It’s paint
Do you experience any rubbing with the 295/65/20 tires?
Looks like the previous owner made some small mods to the front of the wheel well to get by.  The rubbing is limited to the mud guards on the front wheel wells and enough that it is wearing through the first layer of plastic.  I only hear the rubbing when I turn sharply such as backing out of parking areas or tight street turns.  My spare is a 37x12.50 which the width may or may not be better for rubbing.  I may think about moving to 35s on my next set but not sure.
I had an order in for a new 2500, but it still hadn’t been picked up by GM after about a month. So I found this one a few hours away, and I picked it up on Saturday morning.
On 10/27/2019 at 1:10 PM, silveradolt18 said:
What is your wheel and tire set up? Stock suspension? Looks awesome
N/A
Edited by BowtieOwner
Traded my 2015 GMC Sierra 1500 SLT 4x4 6.2 for this beast. 2021GMC Sierra 2500HD SLT 4x4 6.6 gasser.
