4 hours ago, bhales said:
my 2022 AT4
What size tires are those? Switching to Ridge Grappler's when my factory ones wear out.
Fuel Sledge 22s +20
Toyo Open Country ATIII 35x12.50x22
Stock suspension, no rubbing.
IMG_5461.thumb.jpeg.f2125fbbdfdc0b091821ae17aac39607.jpegIMG_5459.thumb.jpeg.6e77dc0819c2a3da997c5e1d7706576f.jpeg
Edited by HD AT4
35 x12.5
  • 4 months later...
On 12/12/2019 at 7:24 PM, cdh7917 said:
Truck got some new shoes today.
Fuel Blitz 20x9 +20 offset & Nitto Ridge Grapplers 295/65/20.
http://i.imgur.com/FaCvt9f.jpg
http://i.imgur.com/rJGklx4.jpg
http://i.imgur.com/ZEB2aNi.jpg
http://i.imgur.com/U5EjhMW.jpg
I know this is an old message but can you post a pic of your truck with these wheels again.  I remember seeing it and was thinking I might go this route for the new one I ordered.
  • 9 months later...
6 hours ago, CRApex said:
My 2024 High Country 3500HD Gas.
Looks nice. You wasted no time replacing the wheels I thought the stickers looked good too though. You sell um?
Thanks.  They were on my previous truck and only had about 2000 miles on them.  I usually keep the originals and throw ‘em back on when I trade.  There seems to be a tad more room for some reason on this truck.  I had to tie back the liners on the 2020 but they just barely touch the liner on this one.  295/65/20 with a +0 offset.
2023 high country 2500 gas
Traded my 22' Sierra 2500HD AT4 Gasser in on a new 24' Duramax, I also took the GY's off and put on a set of LT285/65R20 Michelin Defender LTX Platinum's.
