5 hours ago, HoustonVol said:
These folks have a pretty good video on installation for those thinking of tackling this project.
This video is great. Wish I had seen it before doing the install. I'm surprised they are selling their kit for $1200 though. I got my parts for right around $820. And that was a full spoiler rather than just the light assembly.
I agree, 1200 is a lot for this mod.  So far I have found the stop light and spoiler on Ebay for 224 and the cable on amazon for 35.  I'm currently searching for the mirror but no luck on Ebay or amazon.  The Cadillac one is slightly cheaper but still in the 500 dollar range.  I guess I will buy the other 2 first and wait for a good camera deal or a good bonus at work.  ?
We are all in the same boat, I installed everything yesterday, just waiting on a deal for a mirror now im thinking $400 for one but we shall see
Sent from my SM-G973U1 using Tapatalk
On 7/11/2020 at 6:33 AM, Kyle's AT4 said:
Here you go. I found some camaro ones for 200 ish I just need to verify they fit2ab98192beb6a759034c55d588692fa0.jpg
So has anyone confirmed that the Gen 1 mirrors don't work with our truck's?
Edited by Robert G
spelling
i used a blazer mirror for mine. it hooked right up.  pictures great.
Can you post a pic of it?
Hi , I have 2019 GMC Sierra 2500 Denali .  I was wondering if this will work for me, my mirror has OnStar built into it.
You need the new body style (2020+). Unless someone has a retrofit solution.
I have the third break light only, not the whole panel thing that has to be removed from inside
I got my mirror today, already have the cable, now just waiting on the spoiler with the brake light and camera.  I should get it on Monday, so I guess it will be another week before I install it.  I was tempted to get the Gen 1 mirror, but the Gen 2 mirror had more updates that include:
  • Frameless Design
  • Increased brightness adjustments, from 3 to 5
  • Zoom function
  • Tilt/position adjustment (of camera)
  • Increase in the screen and camera resolutions from 1280×240 pixels (Gen 1) to 1440×300 pixels (Gen 2)
So I have all the parts now.  I have a used Blazer mirror and a take off spoiler and a new cable.  Before I take the headliner down I wanted to make sure the camera works.  The mirror shows the blue screen with the camera on it but with just the camera plugged into it it is not working.  Do I need to hook up the brake light wiring for it to work or should the camera be working without the brake light wiring plugged in?  Surely I am not the only impatient one around here.  ?
I tested mine before pulling the headliner. I unplugged the stock mirror so I could get power to the new mirror. I did not utilize the brake light, I simply used the new cable and tested the camera inside the take off spoiler I had, and it worked.
It's a closed system, the mirror should be blue with power, and show video when you hook up the camera. I'm not sure how the camera got power, since it looked simply like a coax cable. However, it must have power over that cable as well. I think the brake light is separate entirely.
Thanks Brian.  I think the camera is bad.  I have the Blazer mirror hooked up and the long cable hooked up to the spoiler camera only and nothing.  I even put it in drive to make sure that wasnt an issue.  Thats the  bad thing about used parts.
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
