okay you guys i know this might sound odd but i am trying to find some led lights to replace the park sensors on my new bumper. the reason is it is a bumper replacement bumper and it is only made with the holes pre-drilled and my pickup is NOT equipped with the park sensor feature. i have looked every where trying to find the size of the holes so that i can kinda narrow down my search but i am not having any luck. i am hope maybe yall have some knowledge to lend me.
thank you in advanced!!
I'm not sure what you're going for (purpose of the lights) but i think it's a really interesting idea.. I was looking at this thread here a while ago, and I'm thinking maybe these bolt led lights might fill that hole pretty well.
I'm thinking these might be rather easy to use, once you find the size and color you're looking for.
Please keep us posted and let us know how it turns out.
I am going to look into those. My main reason really is to fill the holes for the sensors without using a rubber plug. Looking for maybe amber or just white for the front and red for the back
I would imagine you could get pretty trick with them, depending on how much time you want to invest in it. You could have the outer one on either side, front (amber) and back (red) tapped into the turn signals.
Then middle ones in the rear could be tapped into the brake lights (red). The front middle ones you could use white, and have them on tapped from the headlights, or on an independent switch.
It all depends on how much time and imagination you want to invest.
Thanks for the idea!! I didn’t even think about tapping into the turn signal !! Thank you! I will keep you up dated on this!
I am not sure. I need to measure the holes for the sensor but my pickup is in the shop right now...
Okay, so I went and measured the holes for the rear bumper. They are 1”. So would it be best to find an led light that the housing is 1” or pretty close and has threads and a nut for the back and the head of the light be a little bigger than 1”? What do y’all think?
13 hours ago, Mtnsackett said:
Here is another option that is duel function and there is a chrome ring to hide any rubber.
https://www.bigrigchromeshop.com/led-mini-dual-function-clearance-marker-with-bezel-p-12277.html
I think these might be the way to go! Size would work, and you could always paint the chrome rings if you're going painted bumper.
Yeah but what holds it in place? The body of the light which is 3/4” is what goes into the hole which is 1“.  So how does it stay in place? That outer ring just keeps it from falling all the way through. It won’t keep in secured. Correct?
You know what, you are correct. I hadn't noticed till you asked, but those lights don't have the locking nut behind them to hold them in place. That's my mistake. What you would need is something like these, which have a threaded back, so you would be able to tighten it against the back side of the bumper.
https://www.amazon.com/gp/product/B07CMN6FD5/ref=ox_sc_saved_title_7?smid=AQU08BEB4MN2K&psc=1
These look a little bit larger
https://www.amazon.com/dp/B07CWQZ212/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B07CWQZ212&pd_rd_w=lelbM&pf_rd_p=45a72588-80f7-4414-9851-786f6c16d42b&pd_rd_wg=9TmC9&pf_rd_r=TEFM1K3KC8J7P5GCRASP&pd_rd_r=21117b32-a1e3-456a-95e8-2e60bbb7809f&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEySkRMTEwyUkMxTThMJmVuY3J5cHRlZElkPUEwMDQ4MzAyMTMwSExJQTQ3Vlg2RiZlbmNyeXB0ZWRBZElkPUEwMjk3MDg5MjZQNk5DWktDSllMTyZ3aWRnZXROYW1lPXNwX2RldGFpbCZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Edited by CustomChevyGuy
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
