I have a 2020 2500HD crew cab. black leather interior. I have the fold down console, with upper and lower storage. Would love to swap for a Center console like in the LTZ model. Mine is an LT. Thanks
  • Replies 39
Top Posters In This Topic
Does anyone have the GM parts number for the jump seat with glove and seat compartment plus rear vents for a 2020 Chevy 2500 HD.
My WT model doesn't have either compartments.
I attempted to buy one on eBay with bad results and had to return them as one was totally thrashed and the other had no jump seat compartment.
  • 6 months later...
Hey Guys - new to the site.
I have a 2016 GMC Denali 2500. Looking to remove the center console and replace it with a jumpseat for the 4th kid.
Does anyone have a part number for the 2020 black leather jumpseat?  I want the newer model that has the shoulder harness. Thanks Woody
  • 11 months later...
On 1/5/2021 at 9:45 AM, brose05 said:
Yes. This pic below is from a buddy that has a 2020 3500hd denali. Converted to the 6th seat all leather. Has storage top and bottom including all the accessories behind it. The woofer was mounted under the rear seats. Woofer can be abandoned as well with no issues to sound system. The seat is from a 2019/2020 which is the new style so it was just a simple bolts out and back in. No welding no issues. Simple swap.
I have a 2021 3500hd denali that I am looking to do the same to. If someone wants to swap me for their jumper seat that has storage top and bottom including the 2 usb and air vents in the back let me know. I have the jet black leather interior.
Do you have any updates on your swap? What did you do about the rear heated seat buttons?
  • 8 months later...
 Where you ever able to find this?  Could you share the information?
On 10/9/2020 at 3:26 AM, Ms295b said:
So I habe a 2020 2500 HD Custom. I have a jump seat but no storage compartments. Any ideas where I can find a replacement that has the top and bottom storage compartments along with the AC vents and USB in the back?
Thanks.
Where you ever able to find this?  Can you share the info?  Looking for the same
I'd LOVE to do this in my 2024 AT4 3500, but I suspect the angled dash in the AT4/Denali trims would make this difficult as there probably isn't any trim piece to replace the space under the dash where the console used to be. If anyone ever tackles it, please share!
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
