It just happened tonight, I am going to call them tomorrow.
I travel a ton for work, usually 1000-1500 miles a week. I can't afford to have doubts about my truck not working.
I will post back what they day.
Tom
I had a few days of no problems then...
I was driving from Minneapolis to Kansas City today. My truck started throwing up tons of error codes and wouldn't restart after turning it off. It wouldn't even crank.
I unplugged the Pulsar and took it out of the system, everything fired up.
I am going to ship it back, not sure it is fully developed yet.
Tom
That’s what mine did. Powerteq has my device and will be testing it out along with my first device that also failed.
At the very least you should call them and tell them about your issues so they don’t think I’m the only one.
Just another reason why I’ll wait and have all the bugs worked out of this thing. Too many issues right now.  Hopefully by spring they will have kinks worked out.
Who knows, maybe the tuning industry will drop their prices by then??‍♂️??
You had 2 fail on you?
First one was a bad unit all the way around.
Second one worked like it should for about 7 days then I had the same issues you did out of nowhere.
Call them!
The under hood connector these things plug into is prone to failure. I’ve seen them replaced on about 5 trucks for strange electrical issues similar to what was mentioned above.  So it makes me wonder how the failed units were installed.  For instance any difficulty getting the connector apart initially and/or any difficulty installing the unit maybe damaging the connector/connector pins inside the factory connector or the device connector and causing some issues.
Aside from some tabs that were a bit too long on the pulsar connectors causing a slight torment issue, the original connector was easy-off and the new one was easy-on. They are the same brand (Delphi) as the factory connectors.
What exactly fails on the connector? I had to file down those grey tabs as well. Once they were filed down the module engaged perfectly. It seems like a great design to prevent the plug from coming loose. If the cam is fully rotated and the red lock seated all the way in, I dont know how it could come loose.
On 11/6/2020 at 7:22 PM, Jav_eee said:
Filed down these two tabs a bit and all is well. Install, my issues aside, is easy. Fifteen minutes tops!
If GM ever has a question as to whether or not you modded this vehicle... you just answered it, permanently. LOL
 Yeah you’re right! Except if they ask I didn’t touch a thing. Must’ve come from the factory like that. Also after cleaning it up you can’t tell it was modified. Bottom line: I’m not worried about it.
You really shouldn't be. If you read the range warranty you are on your own dime regardless.
"The SELLER disclaims any warranty and expressly disclaims any liability for personal injury or damages. The BUYER acknowledges and agrees that the disclaimer of any liability for personal injury is a material term for this agreement and the BUYER agrees to indemnify the SELLER and to hold the SELLER harmless from any claim related to the item of the equipment purchased. Under no circumstances will the SELLER be liable for any damages or expenses by reason of use or sale of any such equipment."
Edited by It's Tim
What fails is the connector is the connection of the pins in the connector.  That connector design doesn't make a good connection for all the pins in the connector.   So if and install didn't go smooth, it may have worsened the condition of the connector.
I'd recommend to those having problems, apply some dialectic grease to the connectors and see what happens.  Maybe I'm wrong, but like I said, I've seen too many issues with these connectors with out being tampered with.
Edited by SILVER SLED
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
