I've been plugging my truck (2020 3.0) in during the nights it gets in the 20's and 30's where I live (southern Indiana) because I'm a volunteer firefighter and don't want to jump in a cold diesel and take off. Granted my truck is in an attached garage, but it still is cold in the garage. When I get in the truck in the morning to start it for work, it comes up on the temperature gauge between 160* and 210* marks. Not sure if the diesel thermostat control is different than the gas trucks.
Edited by mjonesjr84
The cords in the Diesels will work when the temps get into the 30s, don't worry about that 17 degree crap.  Even in my LMM Duramax trucks (2- 2008) and the LML (2012) the block heater would engage when the temps were in the 30s.  The engine started easier and in some cases, there was already warm air for heat.  Get the block heater installed, you won't regret it.  BUT let me suggest that if you tend to park it at night and not need it again until the morning, put it on a timer.  heavy duty timer. (and extension cord) Why?  The block heaters in the big boy duramaxs uses 1000 watts of electricity.   And you will notice it on your electricity bill!  OUCH.   Setting it to come on 3 hours prior to your departure will be plenty of time for things to get warmed up, unless you live up in Alaska or the Canadian north.
Edited by Colossus
The "baby" Duramax 3.0 in the 1/2 tons also use 1000 watts according to my 3.0 cord tag.
Don't use one of those cheap Christmas light timers. I make these up for all the farm equipment. Take a 12ga cord and cut off 3 foot of the male end and splice this timer in between.
On 12/17/2020 at 5:20 PM, Grover67 said:
Yep normal temps, it'll steady out more you drive it and temps stabilize. There is alot going on and if you get a chance read up on it on why there is fluctuations on how the cooling system works
-Grover67
Mine is just a needle width passed the middle of the gage once warmed up.  It stays there and doesn't move, no matter what.  I only have 250 miles on my truck though.
On 12/17/2020 at 6:21 PM, jmer98 said:
Where can I find that information?
Sent from my SM-G986U using Tapatalk
This is a good vid on the 3.0l
Today it was -20 C . Plugged in the block heater and it worked. Current draw is 3.5 amps. Glad it works but still not impressed that its has to get so frigging cold before I can make use of it
On the 3.0 the block heater works all the time the dealership recommends the truck not be plugged in until temps reach-18c.I did this with mine and the temps warmed up to -12 overnight and when I started the truck the engine fan kicked into high and would not turn off ( apparently has to sit for six hours to stop this problem temporarily) finally convinced dealer of issue and their replacing a sensor and a thermostat. There was a bulletin on the issue but when I posted on the issue I got no feedback so I assume it wasn't a common problem.
I agree. My last two trucks have had this abysmal system. Before that I was in control of the block heater like it should  be. Now it doesn't activate when it should and you can get hard starts and lots of noise. It wouldn't suprise me if it doesn't start one day due to the ridiculous design. Ive read that bypassing the cord thermostat will cause big problems due to the trucks programming. GM should be ashamed for forcing this unreliable and subpar system on cold weather owners. Kudos to the guy that installed his own heaters. The remote start hasn't worked on my last two trucks around -20 either.
Edited by Minnvmax
This motor lost me when the transmission has to be removed to service the wet belt oil pump drive. Listen carefully. "Simply" is the word used to describe belt service and...and...and it's no harder than from the motors front. Okay.....:wtf:
People think gasser AFM/DFM is complicated?
Eh, I'll spend the cash when I get to the 150k mark to get the belt replaced. It is warrantied until 100k.
I'll take the 24+ mpg in a 4wd truck any day.
Everyone should be happy with their choice.
Enjoy yours.
where can i find this timer box online?
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
